Program does not work like I want it to
I'm new at this, I can't get my yard lights to turn off when I want them to,they stay on all night.
Until dusk to dawn shuts them off. It turns on OK, but not off.
Here's a picture of the program I'm using, I just need a little help until I become better.
Thanks Tim
Darn , I see the problem, I have it being turned on instead of off :oops:
You need an "On" and an "Off" command to do both. The "Responding" condition shouldn't be in there.
Multiple times need to have "OR" logic. Both can never be true at the same time and therefore your "Then" will never get executed, only the empty "Else"
. On Sat, Mon, Wed
. Time is 2:00 AM
OR
. On Fri, Tues, Thu
. Time is 1:00 AM
. Set 'YardLights' On
. Wait 2 Hours
. Set 'YardLights' Off
Your post mentions wanting your yard lights to turn off, but then your program has them turning on.
Perhaps you can better clarify what you want?
I'm guessing you want them to turn off at 11 PM Sun-Thurs, and 2 AM Fri/Sat (really Sat/Sun)?
If so, I would use this:
       On Sun, Mon, Tue, Wed, Thu
       Time is 11:00:00PM
    Or On Sat, Sun
       Time is  2:00:00AM
       Set Scene 'Outside' Off
You don't need to check if they are on, just turn them off. If they are already off, they will stay off.
       Time is 11:00:00PM
    Or On Sat, Sun
       Time is  2:00:00AM
He edited his post yesterday pointing out that he made a silly mistake accidentally commanding the lights to turn on when he meant to put off.
