AT&T to end email-to-text ×
can't add new motion detectors
I have about 7 existing motion detectors in my house which work fine.
I recently tried adding two more motion detectors however every time I get and error that ISY couldn't determine the engine.
I read online that I should set my modem and the wireless receptor next to each other.  I did this but it doesn't seem to work.
Battery operate devices need to be put into "setup mode" or they will not respond to requests from ISY.
Usually this takes an extended button press until the LED flashes and/or the device beeps.
Don't forget to always factory reset your new devices when you first use them. Internal settings have caused me a lot of grief when I haven't bothered.
