Use a Smartenit model #5010A irrigation using ISY-994i with Ham weather.
I want to control my  8 zone
irrigation system using ISY994i and having (weather bug) not used anymore now its Ham Weather at ($25.00 per month) tell my irrigation system its time to water the yard .  Can this be set-up like this? THANK YOU. .
I'm new with this stuff, so this I'm sure its a stupid question, why would we wamt a weather service to hook up to and ISY if you can't use it to control something ?
Whats the best way to controll a water system using weather reports?
Edited by easytim
Its something I read, but I'm new so what do I know.   Your saying Ham Weather is free? Thank you
  • 10 months later...
I just purchased this 5010A EZFlora but my ISY-994i says it is not supported. Is this true?  How can I control this thru the ISY-994i? I have the 4.2.30 firmware installed.
Run Tools | Diagnostics | Event Viewer at LEVEL 3.
Use New INSTEON Device to add EZFlora and post event trace.   I just added an EZFlora to 4.3.1.  Don't think there were any changes added to 4.3.1 in this area.
Also click Help | About and verify UI is 4.2.30.
Thanks for the answer. It took three tries before ISY recognized it. I am running 4.2.30. I want to set this up so I can control remotely while on vacation. My sprinkler runs off my well which I have set to turn off when my alarm is armed to on and it turns back on when the alarm is disarmed. This way I can remotely turn well back on run a sprinkler program and then have well shut off again when watering is done. Water is never on when house is unoccupied.
