ISY99 Pro lock up
I have a problem with unit frequently locking up when accessing over the Internet. I need to unplug and plug again to regain control. I can not point to any paticular operation cousing this behaviour. Recently it happened when changing LL level. I logged in remotely and after couple minutes unit was down. I will have to go back home to reset it. Any suggestions what is the possible problem solution are appreciated.
Thanks for the help - Walter
Hello Walter,
Apologies for the inconvenience. What firmware level are you using?
There seems to be a bug with release 2.6.6 which we are trying to confirm. If you have a version other than 2.6.6, please do let us know as it would help us finding the issue.
