FanLinc With Hunter Ceiling Fan/Light
We have several Hunter ceiling fan/lights(model 25734) in our home that are controlled with Hunter remotes. The remotes are starting to fail and I would like to replace them with FanLincs.
I have attached pictures of the remote transmitter receiver and nine pin plug that plugs into the receiver.
Will FanLinc work with this ceiling fan?
dbuss,
In most cases you have to strip out all of the control to the bare minimum.  A set of common and hot wires to the light and a set of common and hot wires to the fan.  If the fan is a multi tapped motor with a separate wire for each speed then you need to connect the fanlinc to the high speed wire.  All of this comes with no guarantee but it has been done before and it will be done by others again.
the two common wires from the fan and light go together along with the white wire for the fanlinc and the neutral wire coming into the box.  Then the fan wire of the fanlinc goes to the high speed winding wire off the fan or if it only has one hot wire to the fan than that one.  The other wire left over from the fanlinc goes to the light.
