jcassar Posted August 13, 2014 Posted August 13, 2014 Just bought the Climate module and cannot make it work. Going to Configuration->Climate I pressed the Locate Me, this seems to work and get the closest town (where my ISP is located). I select the town and a list of station appears. I then select the station, then press Save. All numbers shows 0. If I press View all, a web browser session is opened on HAMWeather.com with the URL http://wx.hamweather.com/?pands=MID_C2984, with MID_C2984 the station code, but nothing is found on the site. If I enter the zip code, then the web site shows the correct information, but on the UD Admin Console, all numbers are still 0. Refresh values are still 0 after hours. I attached screen captures showing this problem. Any ideas will be welcome. Don't want to waist $49. Thanks! JP
LeeG Posted August 13, 2014 Posted August 13, 2014 What ISY firmware is being used? What does Help | About show for Firmware and UI? Need to be at 4.2.8 for both Firmware and UI.
jcassar Posted August 18, 2014 Author Posted August 18, 2014 Thank you! I successfully upgrade (matter of) to 4.2.8 and the information are now available. BTW, upgrade does not work from a Linux client (in this case Fedora), got a zip integrity issue but works fine on Windows.
