Dashboard showing 2 states
Hello,
In my Ajax dashboard, some devices are showing both on and off. Admin console and mobilinc show the correct state. Any ideas?
FYI these devices in the screenshot are from an EZIO8, however I see th same issue also with other devices.
Thank you.
Edited by ravedog
Interesting. So all scenes light up as both off and on? Why would that be? Can you clarify?
From an Insteon perspective Scenes have no Status.  A Scene is not On or Off.
Under ISY Programs, "Condition" Status and Control cannot test a Scene for On/Off.
Under Dashboard the On/Off buttons select the command to be applied to the Scene.  They do not reflect Scene Status as Insteon has no concept of a Scene Status.
Makes perfect sense. Then maybe the iconography could be different or both off. Or something else. Thanks LeeG for the explanation.
