Remote Connection to ISY Security
All,
Wha is the most secure way to access your ISY when you are away from your house ?.
HTTPS: or set up a VPN connection.
Edited by Teken
Teken,
How would a newbie find this info on how to do this ?
Teken,
Oh and is there a cost for this
Teken,
The easiest thing to do is port forward your public IP address in the router. Look up port forwarding in Google with the specific router you have on hand. Once that is done you can decided to either use the default HTTPS: 443 port or another one of your choosing.
Many select another port besides 443 in hopes of being sneaky and be more stealth like, thats up to you! I would go that route before you even started down the VPN path.
Essentially, a VPN is a secured tunnel to and from your location to the home. This allows you to connect to a network device / computer system and do whatever.
Also, not to muddy the waters a VPN encrypts the session / connection. It does not encrypt the data / payload of data with in.
There is no cost to setup port forwarding on your router just a few moments of your time. A VPN service / software can be purchased but many choose freeware to accomplish that task.
Teken,
I currently am using port forwarding and everyhting seems to be working, can I assume this is secure enough ?
Teken,
Are you using port 443 to access via the interwebs via HTTPS:?
I type in my IP that the ISY assingned (I believe it said https: I am not home to verify this).  I do have it on the defualt port 443.  To access I just type the IP in the browser and I gain access after entering the password
I would say you're in good shape then.
In the big picture guys like you and me have nothing to take. That doesn't mean you don't follow best security practices which you're already doing now.
As I am sure you're aware there are some security items that need to be done on a regular basis.
1. Use a strong password which includes alpha numeric, upper  / lower case, special characters, a minimum length of 8-12 characters, using non standard words etc.
2. Change your password on a regular basis.
3. Turn off the SSID to the router for WiFi.
4. Always ensure your firewall / anti virus is up to date and checked regularly.
5. Use MAC address restriction(s) and MAC reservation so random devices can not sign on.
6. Black Hole detect should always be left on. Meaning if someone pings your router it will never reply back.
7. Using a VPN connection is really one of the best methods to ensure a secure session.
8. You should always avoid using any free WiFi in coffee shops etc
Thank you for the info, very much appreciated
Speaking of password lengths... Does the ISY team have any plans for allowing longer passwords? 10 seems.... Fairly weak for something that's outward facing...
I second longer password length. Should allow up to 25 characters for both user name / password.
Encrypted By: Phoenix Security Solutions
Well. Keep it in mind if you can manage it
