Measuring Rainfall with a Hydreon Sensor
The Hydreon RG-11 is a non-mechanical, optical rain sensor. Its reliable, rugged and unbreakable. Based on a post by jrainey,(See post #3) I bought and installed a Hydreon sensor to emulate Tipping Bucket and measure rainfall on my property directly. Like many, I was getting mixed results by counting on results from local net based WX. It was good, but observation said it could be a lot better. This tutorial is what's needed and how to install it. It ends with a sample program to calculate rainfall.
What the Hydreon does
  • It closes or opens (NO/NC) contacts in response to a certain amount of rain drops falling across its optics
  • Each close represents a certain amount of rain fall:  .01", .001" or .0001" (There's metric too)
  • The clicks are intercepted by a contact module, IO Linc
  • Those clicks can be counted up, calculated into rainfall and acted on by ISY Programs
Hydreon Requirements
  • 12 Volts to 30 Volts AC or DC
  • A device to receive the contact clicks
  • Open space to mount it
My Parts list
  • Hydreon RG-11
  • Insteon IO Linc 2450
  • Enercell 12vdc 300ma Adapter (Radio Shack 273-315)
    • Plugs into IO Linc open outlet
  • Strong 4 conductor project wire. I prefer Thermostat wire
How to do it (See pictures and diagrams)
  • Hydreon
    • Set the dip switches for sensitivity. I used the default, .01" per closure
    • Feed project wire through the nut on the bottom of the Hydreon
    • Connect wire colors for power that will help you remember positive and negative
    • The positive terminal is on the far right as you connect it
    • The Normal Open (NO) and ground are on the left. Contacts don't care which wire hooks to which the IO linc
    • Mount it, clean the hydreon, and string the wire to the IOlinc location
  • IOLinc and Power
    • Connect the to contact wires to IO linc's Sense and ground (see pic)
    • Cut the Enercel cable to fit. The lead with the black stripe is negative
    • Solder/Wire nut the connections from the power supply cable to the Hydreon cable
  • ISY (See pic)
    • Add the IO Linc if you haven't already and name it
    • Mine is "Garage Hydreon Sensor"
    • Click options and set up per pic
    • The contact closure (NO/NC) of the IOLinc are not used for the Hydreon, they are available
  • ISY Progam
    • Here is a sample, it will let you see it in action.
    • Based on the program counting up, you can set a variable and cancel your sprinkler routine
        Status  'Yard / Sprinklers / Garage Hydreon Sensor' is On
        $Rain_Count += 1
Results
I've been getting good results with mine. I've been through 2 rainstorms and it seems to be close. I know exactly how much water I've been getting. My local WX stations are all over the place. My previous WX based weather saved money, but I could observe things not working right.
Here are other things the Hydreon can do. It can perform a number of applications together with ISY:
  • "It's Raining"-- Close a skylight at the first sign of rain, and open it when it stops raining.
  • Condensation / Frost Sensing
  • Wiper control
  • Irrigation Control-- Turn off water if raining
  • Drop Detection
Excellent write up Paul.
