Using sensors from Cox Home Security
I cancelled my Cox Home Security monitoring because it was a dumpster fire.  As part of the initial installation, I had to purchase all the door and window sensors as well as a glass break and a couple of motion sensors.  Cox took back the head unit, which was a SMC device.  As far as I can tell from all the reading I've done, all the devices are Zigbee devices.
I believe the door / window sensors I have are : http://www.openhome.io/deviceDetails?productId=59
Can I talk to these things?  Will an ELK system talk to these things?  Are they useless?  Should I rip them off the doors and windows and start with something else?
edit : It says they are Zigbee modules - "MCT-320 SMA is a fully supervised, compact Zigbee door/window contact transmitter, designed primarily for protecting doors and windows. Suitable for any residential or commercial environment this low-profile transmitter gives the added advantage of a particularly small size that allows for highly flexible and virtually invisible installation. The MCT-320 SMA boasts impressive wireless range, while maintaining a long battery life."
Original :
Doh, that's a bummer.  Guess I should start peeling these things off the windows and doors.
For security integrations, is there a certain system I should stick with that works real well with the ISY?
Edited by naPS
For security integrations, is there a certain system I should stick with that works real well with the ISY?[/size]
With that as your only condition, no question the answer is Elk. I use it - and I'm very happy. Elk becomes a first class citizen in your ISY.
However, DSC based systems can be integrated well as well using a RPI based bridge and dsclinc (http://forum.universal-devices.com/forum/40-dsclink/)
I am confused. I thought that the ISY Zigbee module would provide for communication with Zigbee devices.
Thanks, Michel. That is a key bit of information that should be brought front and center in the Zigbee Module description.
