programs and timers disappeared
andrew77
Hi Guys;
Probably just a little problem easily solved but I can't seem to get my ISY programs and timers back.
When I look at the GUI, I have all my devices and they all work, etc... but my programs and timers aren't there.
My programs (such as a double tap SWL turns on three lights blah blah blah,) works still but I can't see them on the GUI. Andht etimers don't work at all.
I don't believe it's my firewall like DBaldwin worked through.
A simple fix?
Drew
Hi Drew,
If your timers do NOT work then it's not a firewall issue. None of your programs are listed?
To test, add a new program, close your browser, restart it and let me know if the new program shows up.
Hi Guys;
A simple fix?
Drew
Hi Michel;
I've added a program and when I go back it's not there.
This is odd as everything's been running fine for a while now.
I still have issues with the power supply in my computer but I just make sure that it's in standby when it's not in use.
Drew
Drew,
I guarantee that this is related to your firewall software (same issue as DBaldwin).
Hi Michel;
Drew
I only have the windows firewall. Is there a setting I should change?
I shut off the firewall completely and wrote a new program. I closed all browsers and tried the ISY GUI again. Still no programs or timers.
I should say that my triggers still work. Just no programs and timers.
Drew
Hi Drew,
What URL do you use to access ISY? http://www.universal-devices.com/MyInsteonISY or do you use the local IP address for your ISY?
Also, have you tried clearing the Java cache?
Drew
My programs are back, thanks. You guys know your product inside and out.
My timer isn't working but I think that's my bad programming.
Thanks again,
Drew
      37.6k
      376.2k
