Door Sensor Program Problem
Objective: When KPL G is pressed, wait 5 minutes to give me time to exit the door, then send an email notification any time thereafter that the door is opened or until KPL G is turned off.
Kitchen KPL G is 100%
Wait 5 minutes
Run Deck Door Open (Disabled)
No Action
Run Deck Door Open Program (Disabled):
If Door Sensor is On
Send Notification
No Action
The program runs only for one cycle and all further door openings do not result in a notification.
By the way, I still haven't been able to figure out how to post programs here.
Edited by smokegrub
Smokegrub,
I like your questions, I am learning a lot.  To post your program in the admin console right click on the program and copy to clipboard.  When you are typing your post click the code icon, looks like this "<>" and paste into the box.
I think your problem is that the deck door program is disabled, so it only runs the one time it is called by the first program.  I think you need to have the first program "then enable program 2" and when G is off disable program 2.  Maybe in the else for the first program "disable program 2".  We'll wait for one of the experts to give us the answer.
Eric
Right click on Program name, select bottom entry "Copy to Clipboard".   Paste into post.
Need to see actual Program.  The If statement in first Program does not indicate whether Status or Control is being used.   The first Program is triggered once when KPL button G is pressed On.    Nothing else triggers Program so program activity happens only once.
Something like
Status Kitchen KPL G is 100%
And Status Door Sensor is On
Wait 5 minutes
EDIT: actually above does not work because there will be a 5 minute delay the second time door is opened.
Edited by LeeG
This is how I would do this:
   Wait 5 minutes
   Enable Program Back Deck Door Open
   Disable Program Back Desk Door Open
Program: Deck Door Open
   Control Door Sensor is Switched On
   Send Notification
   No Action
Hope this helps.
-Xathros
Teken:
Your program is spot on! You also taught me something using the enabled/disabled feature.
Many thanks.
Edited by smokegrub
This what I get when "Copy to Clipboard" followed by a Paste
        Status  'ApplianceLinc' is Responding
        Send X10 'G1/Off (11)'
Edited by LeeG
