2842-222 motion sensor help
Hi All
I have an isy994i, and a motion sensor (2842-222) that currently controls a spot light . Turns it on and after a "wait " period shuts it off.
I would like it to also turn the another light (rear yard) on and after the wait turn it off only if it was not on prior to the motion activation.
So basically if I am in my backyard with lights on I don't want a motion to trigger and turn that light off, but I want it to still turn on the spot.
Can some please help program this?
Ron
          Control 'motion sensor' is switched On
And    Sense  'other light' is not On
          turn it on
          wait
          turn it off
Hi All
Ron
What turns the rear yard light manually?
Try this idea on
Program 1
   MS is switched ON
  Set spotlight On
  Wait xx minutes
  Set spotlight Off
Program 2
  MS is switched ON
  Set RearYardLights ON
  Wait xx minutes
  Set RearYardLights Off
Program 3
  ManualSwitch is switched On        '*( runs Then)
and
  ManualSwitch is NOT switched Off  '* (runs else)
  disable Program 2
  Set RearYardLights On
  Wait 6 hours                                '*  (just in case)
  run Program 3 (Else)
   enable Program 2
Thanks Stu and Larry
I will try tonight based on your comments.
Ron
