Enable Push Notifications
I'm on running IOS 8. I have installed mobilinc and it prompt me to enable push notification. I mistakenly push don't enable.  Now I want to enable them but I can't find where.  See image
Also How do you enable push notification in the ISY?
Mike
Hello,
If you told MobiLinc to disable push when initially connecting via MobiLinc Connect, to turn this back on, open the iOS Settings app and go to:
Notifications->MobiLinc->Turn on Notifications.
Wes
Wes,
I'm not using mobilinc connect.  Can you still use push notifications without connect? I was told you could.
Hi there,
MobiLinc Connect is required for push notifications. There has to be something (our servers) for the ISY to talk to in order to inform of changes in state. With MobiLinc Connect and your direction on what to be notified about in the MobiLinc app, our servers push out your custom message to your iOS devices when the ISY reports these changes to our service.
Wes
Hi there,
Wes
So the only way to alert with out connect is via text or email correct?
If you have the network module, you can send to pushover, pushbullet or other similar services from the ISY.
Thanks  jim
Is this easy to do?
