Program doesn't seem to do continuous calculation of Variables ??
Still struggling with my programming here.
I seem to be having several issues, stemming from variables that I think should be "changing" in real-time actually NOT changing, so my programs don't work right.
For example:
(all are now "state" variables)
IF:
from 12am to 11:59:59pm, same day
Then:
$den temp difference cool = $stat den indoor temp
$den temp difference cool -= $stat den cool setpoint
I don't get the proper $den temp diff cool number all the time.
It always works if I manually run the program.
Also, do any programs that act on the value of $den temp diff cool "see" the moving number as it is being calculated? I.e. before the calculation is "finished"? Because I feel like that may be happening as well.
Similarly, I need a number to constantly be calculated so the result can drive program starts.
IF:
from 12am to 11:59:59pm same day
Then:
$Number of High TD Units Running = $AC Den is High TD
$Number of High TD Units Running += $AC Upstairs is High TD
$Number of High TD Units Running += $Kitchen is High TD
Doesn't seem to provide a correct number of running units most of the time.  The units are "high TD" as determined by the below program:
IF:
$AC Den Cool Temp Diff >=2
  or
$AC Den Heat Temp Diff >=2
THEN:
$AC Den is High TD=1
ELSE:
$AC Den is High TD=0
Again, all of these variables are "state".
Any suggestions on what I'm doing wrong or a more streamlined approach?
Thanks for any help.
A program with:
IF
will run precisely two time a day - at 12:00:00 am where it will execute the "Then" branch and at 11:59:59 pm where it will execute the "Else" branch.
I think what you want is to add a Wait and a Repeat at the end of your Then branch to have it repeat every five minutes or so or change the condition so that it runs when the value of the $stat den indoor temp or $stat den cool setpoint variables change.
Edited by kingwr
You need to find something that will trigger the whole mess. This would usually be your thermostat sensor.
   thermostat_temp < 9999
AND
   ...this runs every time the temperature changes and is less than 9999 degrees AND time is between 12 - 11:59:59PM
   ...do your temperature stuff here
Run
   ...this  runs at 11:59:59 PM every day. You can avoid code here.
Time spans act as program triggers twice per day. Time spans act as true conditions between the times.
A program with:
IF
Wow - my logic and that of ISY programming are way out of sync!  I just thought it would run if it was in that time period.  I guess I've only used specific times before, and not run into this.
Larry - thanks - that makes sense.
So can I "tabulate" a variable that another program is using to make a decision or do I have to use a second variable to equal the one I'm adding up so it changes to the proper value all at once ? Hope this makes sense - see above.
