Syncing multiple controllers and mobilinc
Hi,
UL device 994i and firmware v4.0.5.
I have a number of devices that respond to multilpe controllers.  For example my kitchen lights have a SWL than controls the load and two other KPL buttons that are all linked together.  I created 3 different scenes each with one controller and the other two devices as responders.  This works fine if I physically press one of the buttons (SWL or KPL).  The load switches on or off and the other two buttons reflect that status.  However, if I use mobilink, only the controller in the scene responds.  The other two responders do not.  If I turn on the SWL (which controls the load) from mobile link the lights go on and the SWL has the correct status but the other two KPL buttons are off.  If I try one of the KPL button scenes only the KPL button is controlled and not the other two.  Tried switching on the SWL via mobilink outside the scene (i.e. the device itself) and still no luck.  Is there a trick to this?
Best Regards.
Controlling the scenes is, I believe, the proper course of action.  Controlling individual devices, even if scene controllers, will not result in responders activating.
If controlling a scene from mobilinc does not cause all responders to react as you expect, double check the responder ON levels, at the SCENE level.  Make sure they are not zero.
Thanks Oberkc.  I found my problem and it was complete operator error.  I had unfinished scenes in another folder and was using those in mobilink rather than the ones I had finished.  Still improving on my folder management :)
