Amazon Echo and ISY
madmartian
donhohn,
It appears that you are running the original version of the Emulation system and the Mapper program.
Most people have switched from that Emulation program to the one produced by BWS systems  (available at bwssystems.com) and are using my AWS_Configuration program (available at the-gordons.net).
The current BWS systems jar is 0.4.10. I am running 4 instances of JAR 0.4.10 on a raspberry Pi. The HA Bridge emulator handles about 44 devices per instance. The AWS configuration program is built for the BWS Systems emulator and not the original. It is basically a point and click for configuring the BWS Systems emulator as it reads the ISY configuration. This thread is loaded with information pertaining to that set of programs.
I am not familiar with the older version of the emulator so I am cannot offer more assistance.
here's what happened when I say "Alexa turn on family room lights" she responds ok, but they do not turn on.
source  : upnp device settings requested: amazon-ha-bridge from 172.18.1.111
2015-10-30 15:34:21.637  INFO 5200 --- [nio-8080-exec-9] c.armzilla.ha.upnp.UpnpSettingsRe
2015-10-30 15:34:21.949  INFO 5200 --- [io-8080-exec-10] com.armzilla.ha.hue.HueMulator
        : hue lights list requested: Yw76jans3YgWIpsYDhMPuLYjaJYsrU1immiC5dOp from 172.18.
1.111
2015-10-30 15:34:21.949  INFO 5200 --- [nio-8080-exec-1] com.armzilla.ha.hue.HueMulator
1.111
2015-10-30 15:34:22.183  INFO 5200 --- [nio-8080-exec-2] com.armzilla.ha.hue.HueMulator
        : hue api root requested: Yw76jans3YgWIpsYDhMPuLYjaJYsrU1immiC5dOp from 172.18.1.1
11
2015-10-30 15:34:22.229  INFO 5200 --- [nio-8080-exec-3] com.armzilla.ha.hue.HueMulator
11
2015-10-30 15:34:57.579  INFO 5200 --- [nio-8080-exec-4] com.armzilla.ha.hue.HueMulator
        : hue state change requested: Yw76jans3YgWIpsYDhMPuLYjaJYsrU1immiC5dOp from 172.18
.1.111
        : hue stage change body: {"on": true}
2015-10-30 15:34:57.626  INFO 5200 --- [nio-8080-exec-4] com.armzilla.ha.hue.HueMulator
        : calling GET on URL: http://admin:rmjacv31@172.18.1.4/rest/nodes/33131/set/DON
2015-10-30 15:34:57.891  INFO 5200 --- [nio-8080-exec-4] com.armzilla.ha.hue.HueMulator
        : GET on URL responded: 200
2015-10-30 15:34:58.063  INFO 5200 --- [nio-8080-exec-6] com.armzilla.ha.hue.HueMulator
        : hue light requested: fa6f9631-187b-4889-b828-851a2ce3e95a from 172.18.1.111
        : found device named: Family Room Lights
2015-10-30 15:38:06.527  INFO 5200 --- [nio-8080-exec-7] c.armzilla.ha.upnp.UpnpSettingsRe
source  : upnp device settings requested: amazon-ha-bridge from 172.18.1.30
2015-10-30 15:38:06.620  INFO 5200 --- [nio-8080-exec-8] c.armzilla.ha.upnp.UpnpSettingsRe
2015-10-30 15:38:06.714  INFO 5200 --- [nio-8080-exec-9] c.armzilla.ha.upnp.UpnpSettingsRe
2015-10-30 15:39:39.019  INFO 5200 --- [nio-8080-exec-1] c.armzilla.ha.upnp.UpnpSettingsRe
2015-10-30 15:39:39.113  INFO 5200 --- [io-8080-exec-10] c.armzilla.ha.upnp.UpnpSettingsRe
2015-10-30 15:39:39.206  INFO 5200 --- [nio-8080-exec-2] c.armzilla.ha.upnp.UpnpSettingsRe
donhohn,
Thank you... I will try this way and see if I can get it working.
See if you can get "Jarvis" as the name.
Yes Yes!!! Please!  That would be very nerdy and I'm sure everyone here would appreciate it!   :)
Michael, these would be my skill additions if possible.
Close, like in garage door, does work for other things
Open (kind of works now)
Turn up and down
Change
Enter and exit
Start and stop
Music on or off (doubt this can happen)
Volume up or down (again, probably not possible)
Arm and disarm
Stop and start
get and put
Sprinkler stations or irrigation
Panic
Record
Kill
Input
Enable and disable
Set
Skip, Pause, Select
Fast forward, rewind
Heat and cool
Lock and unlock
Arm and disarm
Lock and unlock
I agree on Jarvis. Love it!
However, I don't think it's a good idea to allow Alexa to disarm an Elk. Or unlock doors. Just sayin'
I use a password, works well.   Alexa, turn on disarm the house password .........  Would just like to remove the "Turn On" or "Turn Off"
Invocation Name... How 'bout a generic term like "Control" or "System?"
Jon...
Or (he treckie in me suggests) 'computer'.... :)
Or the age in me say's HAL....
The above, the above above that and this one should all be ignored (INMHO)
Edited by trevorst
What about Jeeves for Jeeves the valet, Jeeves the butler, who's first name is Reginald and other valets call him Reggie.
Hi Guys,
Just another update: unfortunately we have to go through re-certification again:
1. Home cannot be used
2. The spoken words chosen for our test were not well understood by Echo
As such, we need your help. Would you all please
1. Post back the name of location/devices that you would most likely use with Echo? For instance, Front Door Lock. Or Upstairs Thermostat. Or Bedroom All. Or, in short, whatever you think you would want to call them. We already have a list of about 80
2. The same for your program names
3. Invocation name. Currently we are thinking of using My Home but I very much doubt it'll fly. And, I.S.Y is too cumbersome. Izzy  is not understood: depending on the accent, Echo might consider it "easy".
I'm confused as to the structure of the commands that will be used.  Is it.. Alexa, + [invocation Word,] + [Command] ??  e.g., Alexa, "Jarvis," "Kitchen Lights On"  :)
Jon...
Hello everyone,
Thanks so very much for excellent contributions and suggestions.
As far as invocation names, Jarvis/HAL have nothing to do with ISY and we might even have to deal with copyright issues. I think we should use either i.s.y or izzy. Thoughts?
Michel,
You mentioned in a previous post that Echo confused izzy with easy.  I would prefer a person's name to i.s.y. (because others in the house won't know won't remember i.s.y. - it has no context to them).  How about Lizzy?  "Alexa tell Lizzy to turn on the kitchen lights."
Someone else mentioned a "Z" or "X" name would work.  There are plenty of those in baby naming books.
Izzy is my #1 choice.
Thank you all.
I like Izzy too but we have to make sure it does not get confused with "easy".
The fact that it is preceded by "Tell" should limit the words/names to match against to only the activated skills I would think.
Again, Izzy (male) or Lizzy (Female)  both sound as viable choices. Perhaps Amazon will allow the end user to choose the wake up name from a set of two as it does with Alexa. Perhaps this could be a choice within the skill always starting with Izzy but allowing a command to change the wake up word to either one.
I have just placed a new version of the AWS_Configuration (version 4.0.0) program on my web site (www.the-gordons.net). It is a major revision and handles the Harmony Hub in addition to the ISY. It is configurable as to the inclusion of the Harmony Hub configuration capability, and the default is not to include it. If you do not have the Harmony Hub and are currently running a version of the Configuration system (AWS_CONFIG.com) I suggest you upgrade to version 4.0.0. Version 4.0.0 has changes to the user interface and better code handling.
If you are going to use the Configuration system to handle the Harmony hub, then I strongly suggest you read the documentation included in the Install package. You will also need to be running the BWS Systems Restful Harmony application.
I personally do not own a Harmony system as the ISY994 handles all my needs for Home Automation and I use Pronto PRO remotes for my theater and the various TV's around the house. The New version has been tested in an ISY994/Harmony Hub environment and appears to be working correctly. This means I can not be of much help in setting up the basic Harmony system with the Restful Harmony application, but there are several people who have posted here that are capable of assisting in that endeavor.
      38.2k
      381.2k
