Programming Local On Levels and Rates from Programs
jamesx0
It would be very useful to set on levels and rates through programs. That way, lights can be locally turned on to different levels based on time of day.
Is this true for local levels and button contolled scenes? I have only been able to change scene levels in programs for ISY controlled scenes.
Hello jamesx0,
You are right; this does not work for controllers (buttons) mostly because SWLs require a reboot to have local on level/ramp rate effectuated.
We'll see if we can add some form of control in the programs for KPLs and other devices.
