Motion sensors for directionality
So I was wondering if any one has tried using multiple motion sensors to determine direction? For example, walking towards a room triggers multiple sensors in order which let's you know what room or area to turn lights on for. Or multiple sensors to accurately determine motion in a large room?
What I Didn't see was code for direction. I liked that Lee used variables but it also looks like the order of the trigger doesn't matter so long as both ms are turned on that's all that matters. For me turning on 1 then 2 is different than 2 then 1. Did I Read the code wrong?
I will repost this here then
This takes up to four programs but could be combined into three possibly or jus two if the direction of travel is known. I present it as educational tool.
    MS1 is switched 'On'
    Enable 'Program1'
    Wait 1 Minute
    Disable 'Program1'
    MS2 is switched 'On'
    Enable 'Program2'
    Wait 1 Minute
    Disable 'Program2'
Program1 (disabled)
    do stuff - motion went from MS1-MS2
Program2 (disabled)
    do stuff - motion went from MS2-MS1
