Triggerlinc notifications
TheWabit
So I have my Triggerlinc set in "On-Off" mode (jumper in). I verified that in the admin panel that when the door opens it turns On and when you close the door it goes Off. I have a notification program set up that when you open the door (On), it will send a text. Then I open the door - wait a couple of seconds and close the door and I get 2 text messages. I think I should only get the one when it turns on. Not a bog deal but any thoughts?
        On Mon, Tue, Wed, Thu
        From     9:30:00AM
        To       5:30:00PM (same day)
    And Control 'Triggerlinc' is switched On
        Send Notification to 'Default' content 'Mud Room Door Entry'
Run Tools | Diagnostics | Event Viewer at LEVEL 3. Go through the door Open/Close sequence and post the event trace. It sounds like the TriggerLinc is sending two On messages which can be related to how the magnet interacts with the TriggerLinc.
Here it is:
Thu 11/27/2014 11:42:29 AM : [iNST-SRX    ] 02 50 14.8A.FD 00.00.01 CB 11 01    LTONRR (01)
Thu 11/27/2014 11:42:29 AM : [std-Group   ] 14.8A.FD-->Group=1, Max Hops=3, Hops Left=2
Thu 11/27/2014 11:42:29 AM : [D2D EVENT   ] Event [14 8A FD 1] [DON] [1] uom=0 prec=-1
Thu 11/27/2014 11:42:29 AM : [  14 8A FD 1]      DON   1
Thu 11/27/2014 11:42:29 AM : [D2D-CMP 000B] CTL [14 8A FD 1] DON op=1 Event(val=1 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> true
Thu 11/27/2014 11:42:29 AM : [D2D-CMP 0009] CTL [14 8A FD 1] DON op=1 Event(val=1 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> true
Thu 11/27/2014 11:42:29 AM : [D2D EVENT   ] Event [14 8A FD 1] [sT] [255] uom=0 prec=-1
Thu 11/27/2014 11:42:29 AM : [  14 8A FD 1]       ST 255
Thu 11/27/2014 11:42:30 AM : [D2D EVENT   ] Event [14 8A FD 1] [DON] [1] uom=0 prec=-1
Thu 11/27/2014 11:42:30 AM : [  14 8A FD 1]      DON   1
Thu 11/27/2014 11:42:30 AM : [D2D-CMP 000B] CTL [14 8A FD 1] DON op=1 Event(val=1 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> true
Thu 11/27/2014 11:42:30 AM : [D2D-CMP 0009] CTL [14 8A FD 1] DON op=1 Event(val=1 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> true
Thu 11/27/2014 11:42:32 AM : [iNST-SRX    ] 02 50 14.8A.FD 00.00.01 CB 13 01    LTOFFRR(01)
Thu 11/27/2014 11:42:32 AM : [std-Group   ] 14.8A.FD-->Group=1, Max Hops=3, Hops Left=2
Thu 11/27/2014 11:42:32 AM : [D2D EVENT   ] Event [14 8A FD 1] [DOF] [1] uom=0 prec=-1
Thu 11/27/2014 11:42:32 AM : [  14 8A FD 1]      DOF   1
Thu 11/27/2014 11:42:32 AM : [D2D EVENT   ] Event [14 8A FD 1] [sT] [0] uom=0 prec=-1
Thu 11/27/2014 11:42:32 AM : [  14 8A FD 1]       ST   0
Thanks for the trace, there are two On messages. However, my TriggerLincs do the same thing. Suggest adding a Wait 1 second at the beginning of the Then clause.
LeeG,
For the benefit of others what is your guess as to why the device is sending two ON's? As I don't recall this device ever doing this before.
Is your device fairly new? Do you have any older units to compare?
Several of my battery devices send multiple Group Broadcast On messages.  Do not know why they do, perhaps SmartLabs felt battery communication would need assistance since the device cannot monitor power line for conflicting message activity.
This is from a motion sensor.
Thu 11/27/2014 06:11:18 PM : [iNST-SRX    ] 02 50 14.99.51 00.00.01 CB 11 01    LTONRR (01)
Thu 11/27/2014 06:11:18 PM : [std-Group   ] 14.99.51-->Group=1, Max Hops=3, Hops Left=2
Thu 11/27/2014 06:11:18 PM : [D2D EVENT   ] Event [14 99 51 1] [DON] [1] uom=0 prec=-1
Thu 11/27/2014 06:11:18 PM : [  14 99 51 1]      DON   1
Thu 11/27/2014 06:11:18 PM : [D2D-CMP 006B] CTL [14 99 51 1] DON op=1 Event(val=1 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> true
Thu 11/27/2014 06:11:18 PM : [D2D-CMP 0045] CTL [14 99 51 1] DON op=1 Event(val=1 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> true
Thu 11/27/2014 06:11:18 PM : [D2D EVENT   ] Event [14 99 51 1] [sT] [255] uom=0 prec=-1
Thu 11/27/2014 06:11:18 PM : [  14 99 51 1]       ST 255
Thu 11/27/2014 06:11:18 PM : [VAR  2    7 ]       1
Thu 11/27/2014 06:11:18 PM : [iNST-DUP    ] Previous message ignored.
Thu 11/27/2014 06:11:18 PM : [iNST-SRX    ] 02 50 14.99.51 11.00.01 CB 06 00           (00)
Thu 11/27/2014 06:11:18 PM : [std-Group   ] 14.99.51-->11.00.01, Max Hops=3, Hops Left=2
Thu 11/27/2014 06:11:18 PM : [iNST-INFO   ] Previous message ignored.
This is from a TriggerLinc
Thu 11/27/2014 06:11:53 PM : [iNST-SRX    ] 02 50 11.B6.BC 00.00.01 CB 11 01    LTONRR (01)
Thu 11/27/2014 06:11:53 PM : [std-Group   ] 11.B6.BC-->Group=1, Max Hops=3, Hops Left=2
Thu 11/27/2014 06:11:53 PM : [D2D EVENT   ] Event [11 B6 BC 1] [DON] [1] uom=0 prec=-1
Thu 11/27/2014 06:11:53 PM : [  11 B6 BC 1]      DON   1
Thu 11/27/2014 06:11:53 PM : [D2D-CMP 004F] CTL [11 B6 BC 1] DON op=1 Event(val=1 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> true
Thu 11/27/2014 06:11:53 PM : [D2D EVENT   ] Event [11 B6 BC 1] [sT] [255] uom=0 prec=-1
Thu 11/27/2014 06:11:53 PM : [  11 B6 BC 1]       ST 255
Thu 11/27/2014 06:11:53 PM : [D2D-CMP 003D] STS [11 B6 BC 1] ST op=1 Event(val=255 uom=0 prec=-1) is Condition(val=255 uom=0 prec=-1) --> true
Thu 11/27/2014 06:11:54 PM : [iNST-SRX    ] 02 50 11.B6.BC 00.00.01 CB 11 01    LTONRR (01)
Thu 11/27/2014 06:11:54 PM : [std-Group   ] 11.B6.BC-->Group=1, Max Hops=3, Hops Left=2
Thu 11/27/2014 06:11:54 PM : [iNST-DUP    ] Previous message ignored.
Thu 11/27/2014 06:11:54 PM : [iNST-SRX    ] 02 50 11.B6.BC 22.80.0B 41 11 01    LTONRR (01)
Thu 11/27/2014 06:11:54 PM : [std-Cleanup ] 11.B6.BC-->ISY/PLM Group=1, Max Hops=1, Hops Left=0
From another TriggerLinc
Thu 11/27/2014 06:12:20 PM : [iNST-SRX    ] 02 50 11.B8.2D 00.00.01 CB 11 01    LTONRR (01)
Thu 11/27/2014 06:12:20 PM : [std-Group   ] 11.B8.2D-->Group=1, Max Hops=3, Hops Left=2
Thu 11/27/2014 06:12:20 PM : [D2D EVENT   ] Event [11 B8 2D 1] [DON] [1] uom=0 prec=-1
Thu 11/27/2014 06:12:20 PM : [  11 B8 2D 1]      DON   1
Thu 11/27/2014 06:12:20 PM : [D2D-CMP 0061] CTL [11 B8 2D 1] DON op=1 Event(val=1 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> true
Thu 11/27/2014 06:12:20 PM : [D2D EVENT   ] Event [11 B8 2D 1] [sT] [255] uom=0 prec=-1
Thu 11/27/2014 06:12:20 PM : [  11 B8 2D 1]       ST 255
Thu 11/27/2014 06:12:20 PM : [iNST-DUP    ] Previous message ignored.
Thu 11/27/2014 06:12:21 PM : [iNST-SRX    ] 02 50 11.B8.2D 22.80.0B 41 11 01    LTONRR (01)
Thu 11/27/2014 06:12:21 PM : [std-Cleanup ] 11.B8.2D-->ISY/PLM Group=1, Max Hops=1, Hops Left=0
Thu 11/27/2014 06:12:21 PM : [iNST-DUP    ] Previous message ignored.
      378.7k
