Can not back up "An" ISY but can back others on MAC
Hi All,
I'm Having trouble back up a ISY in customers house Updated to latest release.I'm Getting error
"Could Not retrieve File /CONF/80/.PRP" Any suggestions??
Thanks Tim
The following thread may help..  http://forum.universal-devices.com/topic/10712-cannot-backup-isy-could-not-retrieve-file-conf172prp/?p=86768
Note: change /CONF/172.PRP w/ CONF/80.PRP
I just upgraded my ISY 994i/IR Pro from firmware v3.3.10 to v4.0.5. I noticed that the backup performed during the upgrade processed failed. Luckily, the upgrade appears to have worked as I am now running at v4.0.5 and all appears OK. I then tried to backup again. And again it failed where I received a popup message 'Could Not Retrieve File /CONF/172.PRP'. After clicking OK on this message, I receive another message 'Could Not Create the Zip File.' When I look in the PC folder where I was going to store the backup file, there is a file there but it is only 1K in size.
Any ideas on what is causing this and how to clear it?
Hi EVictory,
I am so very sorry. The problem is that there's a zero size file. What you need to do is this:
1. Telnet to ISY and login (http://wiki.universal-devices.com/index ... o_Your_ISY)
2. At the prompt, type:
RF /CONF/172.PRP
Retry the backup.
Jon
  • 1 month later...
Hi Jon,
I just made it back here to the site...when I try to telnet is comes back "Connection closed by foreign host."
Any suggestions?
Thanks Tim
Hi Jon,
Any suggestions?
Thanks Tim
Hi Tim,
You might open a ticket with UDI http://www.universal-devices.com/contact-support/ to help resolve this..
Jon
