Help with Variables Basics
trying understand how Variables work ...
I can see the VAR_1 Init value change, but not control an actual device
I have 3 programs for this test
Variable ON
        X10 'B2/On (3)' is Received
        $VAR_1 Init To 1
Variable OFF
        X10 'B2/Off (11)' is Received
        $VAR_1 Init To 0
On the Variables TAB / State I can see the value in the Init column change to 0 or 1 when B2 goes On or Off
What  I don't understand is why this does not work
Test device on / off via Variable
        $VAR_1 is 1
        Set '25.C4.73.1' On
        Set '25.C4.73.1' Off
Setting Init value is what the variable is set to when the ISY is booted.   Set the variable itself "Set $VAR_1 = 1" in addition to setting the Init value.
        $VAR_1 Init To 1
        $VAR_1 = 1
        $VAR_1 Init To 0
        $VAR_1 = 0
Edited by LeeG
Also, to trigger on variable changes (when the value changes), the variable must be a 'state' variable.
Thank you for your help ... it works ...
Makes sense now  ... I wondered why Value on VAR_1 State never changed when Init was changing
Jim,
The Init of a variable is only referenced when the ISY boots.
~Mike
