Notifications no longer working
I have a leak sensor, smoke bridge and a few other Insteon devices that send both SMS and email notifications from my ISY994i. All were tested occasionally and have been working for quite some time now. I haven't made any changes recently to the ISY except to upgrade the firmware to 4.2.18. Today, after adding a new notification and sending a test, I noticed none of my notifications seem to work. I am now getting the error message I attached. I've had Yahoo Mail SMTP set up all along so there were no changes there. I do see in the error message the TCP is Mobilinc connect. I have never used Mobilinc connect. I did purchase the module back in December 2013 and planned to use it, but never did. I have tried changing to another SMTP account and even tried to use the Default and nothing seems to work.
Any help on this would greatly be appreciated.
Edited by Kush
Might not be related, but my notifications had unusually high delay times on Saturday for some reason. Some were appearing  up to 4-5 hours after the event. Seems to be fine now. I assume it was something external.
Michel,
    Thank you so much for the quick reply. I am happy to report that all is well. The first thing I tried was to change the DNS as you said, and all started working again. I don't fully understand why changing the DNS would have anything to do with it, so if there is a "quick" explanation, I would appreciate it. I have used Comcast's 75.75.75.75 since setting up the ISY, so I'm not sure what would have caused it to suddenly stop working.
Thank You
Kush
LeeG
    LOL, thanks LeeG. I guess I couldn't ask for a quicker explanation then that! Who would have thought at the exact moment I decided to create and test a new notification that the Comcast DNS would go offline. I guess if I would have tried again at later time I would have found out.
Thank You
Kush
