Naming Conventions
bshepperd
Does anyone have a good naming convention for devices?
For instance, a motion sensor on the south deck has three entries in the device list.  One for low battery, dusk dawn, and state (on/off).  I have tried a number of different options but have not been fully satisfied.  An example could be:
     ddLocation.function
where dd is a two digit prefix for the device.  In this case it could be "ms" for motion sensor.  Location could be the location of the sensor (SouthDeck).  And function could be LowBat.  The full name would be:
     msSouthDeck.LowBat
For a leak sensor under the guest bathroom sink it could be
      lsGuestBathSink.Dry
Common prefixes could be
ms - motion sensor
ls - leak sensor
os - open sensor
ds - door sensor
sd - switchlink dimmer
so - switch link on/off
kd - keypad dimmer switch
mo - micro on/off module
ll - lamplink dimmer
td - toggle dimmer
lr - in-linelink relay
md - micro dimmer
mr - mini remote
etc.
A common problem seems to be in choosing a convention that results in names that are too long.  I am curious to see if anyone has suggestions for a good convention.
Edited by bshepperd
I precede each device with a two letter description indicating the room that the device is located in. Each rooms devices' are in a folder with the same prefix. Same for the scenes. A number following the device name indicates the On-level for that device.
BR
   Devices
          BR Art Wall 60
          BR Ceiling Primary 50
          BR Ceiling Secondary 50
          BR Ceiling Fan
          BR Fireplace
   Scenes
          BR Art Wall
         BR Bedtime
   CR (Computer Room)
   DR (Dining Room)
   EX (Exterior)
   GG (Garages & Gates)
Also IN, KT, LR etc.
interesting.  In your scheme you do not worry about the type of device.  If the on level is 100 or it is simply an on or off type of device you do not have a suffix for the On-level - correct?
This makes sense for lights and switches.  How about a motion sensor or 8 button keypad?
Correct, 100% and On/Off have no level suffix.
8-button KPL
BR Lamp KPLA
     BR LampB Fan
     BR LampC Art Wall
     BR LampD Wet Bar
     BR LampE Torchiere
     BR LampF Pato
     BR LampG Bedtime
     BR LampH Nighttime
Bedtime-bedroom only, Nighttime-whole house except bedroom
6-button KPL
EX Garden KPL All
     EX GrdnA Shed
     EX GrdnB Stairs
     EX GrdnC Patio
     EX GrdnD Grill
Motion Sensor
IN Rear Hall-Motion
     IN Rear Hall-Dusk
     IN Rear Hall-Battery
Leak Sensor
KT Sink-Dry
     KT Sink-Heart
     KT Sink-Wet
I/O Linc
GG Drive Gate-Sensor
     GG Drive Gate-Relay
Thermostat
LR Themostat-Main
     LR Thermostat-Cool
     LR Thermostat-Heat
The prefixes are especially handy when wiring programs. For example, there are many ceiling lights, but only one IN Front Bath Ceiling.
I always try to use nice names or descriptive ones, but then when you use a mobile app that's what it shows the name as.  So in the ISY I realized I could do folders, so made one for each room.  That way when writing a program it was super easy to select things, like "First Floor/Living Room/Lamp" but the problem is in MobiLinc and apps that comes up as just "Lamp".  You can usually rename them on the app but I use different ones and nothing is firm yet for me on what I want.  So I gave up and just have them still in folders to make it easier to write programs, but each device for me is basically "Living Room Lamp" "Master Bedroom Ceiling Light" "Guest Bathroom Light" "Shower LED" etc.
In addition to the suggestions above, I have taken to adding a suffix to my scene names: MBR / MBR_Light.scn as in many cases I have a device and a scene with the same or very similar name.  Having the .scn extension makes it easy to tell a device from a scene.
When setting up variables, it helps to prefix them with s. or i. for State or Integer variables.
I use a convention DDD RRR NAME, where DDD is three-character device code, RRR is three-character room code, and NAME description narrative. I am not sure that this is a perfect solution, but it is the way I started it (before there were room folders, I believe) and I am too lazy to change it.
My biggest (only) hangup is the one identified by416to305...using mobilinc and tasker, any widget I create on the homescreen shows the first few characters of the name from ISY. This is not especially useful for this purpose to have a widget with a name of OTL FRM north (rest truncated).
Hello Oberkc,
When you say three character device code can you provide an example?
I do something similar with mine:
SLD - Switchlinc Dimmer
SLR - Switchlinc Relay
TLD - Toggleinc Dimmer
TLR - Toggleinc Relay
KD8 - Keypadlinc Dimmer (8 button)
KR6 - Keypadlinc Relay (6 Button)
OLR - Outletlinc Relay
OLD - Outletlinc Dimmer
DOT - Dual Outletlinc Relay (Top)
DOB - Dual Outletlinc Relay (Bottom)
ILD - Inlinelinc Dimmer
ILR - Inlinelinc Relay
MDM - Micro Dimmer Module
MS - Motion Sensor
TL - Triggerlinc
HDS - Hidden Door Sensor
BLB - Bulblinc
And so on...
I find for me doing it my way works well, where you have maybe 1 folder for each floor, one for each room, and then I usually do another by device type, like "KeypadLinc" and then in those folders is where I keep the scenes as well, like for example each KPL button has a scene where it's just the responder, so I can light up the LED on it or turn it off with programs, so those are in the folders under the room.  I find that works well, as it's when writing programs that you really want to easily find things plus you can always rename them in the mobile apps, so seeing: "First Floor/Front Entry/KeyPadLinc/Front Entry - KPL B" works best for me since it's super easy to find when making a program plus is descriptive for apps.
Hello Oberkc,
For example
OTL = Outletlinc
KPL = Keypadlinc
IOL = IOLinc
Etc....nothing special here, in my mind. I just like three character codes, I guess. I probably like xathros' codes better than mine
Edited by oberkc
For example
OTL = Outletlinc
KPL = Keypadlinc
IOL = IOLinc
I had a chuckle when I saw Xathros naming convention. Some of them just hit me as I have seen them before stated in forms etc.
DOB: Date of birth
DOT: Department of transportation
OLD: Just some old guy
BLB: Bring Lots oBeer
SLR: Single Lens Reflector?
Edited by Teken
Dunno what I'm gonna do if SH releases a dual outlet dimmer.  Guess I'll have to use DDT!
Isn't that from WWF wrestling a DDT?
Encrypted By: Phoenix Security Solutions
Possibly but in my mind it is: DDT ("dichlorodiphenyltrichloroethane") is a colorless, crystalline, tasteless and almost odorless organochloride known for its insecticidal properties.
IRR: IR Receiver (irregular)
IRT: IR Transmitter (subway line in NYC)
TWD: 2-wire dimmer (texting while driving)
TS: thermostat (tough ...)
and don't forget the latest device
OOO: On/Off Outlet
Teken, SLR = single lens reflex camera
Interesting exchange...  thanks for all the ideas
After reading everyone's preferences I will make a couple of changes.  I was approaching it more from a typical programming environment when I should be thinking of device naming from an end user perspective since it is what is displayed in mobile apps.
To make the programming a little easier I will switch to folders for rooms instead of grouping by device type.  Not sure it is necessary to have a folder for the floors since each room can easily have a unique name in my house.  I will likely having scenes in the same folder.
I had to read that twice!
I use a folder for each room or area. Then I have a sub folder for devices and one for scenes. I'll have to check my isy but I typically use the room name to start the device name. Ex: master lights. If dual band I have added (DB). I do like the concept of adding switch or dimmer. My standard name would indicate that it is a switchlinc. I do add kpl6 or kpl8 to device names, ex master his kpl8. I have added lamplincs or appliance Linc where indicated.
Starting the device name with the room name or at least an abbreviation of it makes it much easier to select it for a program if needed. I may have to shorten up to some abbreviations because some of my names start getting long for kpl buttons.
      378.7k
