Minataur Variable Temp Sensor
Having trouble getting this one to work with my ISY.  I believe the sensor might not be operating correctly.  I turned the potentiometer dial all the way to the right and set at approximately 40 degrees F. to turn on a space heater.  However, on placing the sensor in the freezer (for a quick test) the sensor is not triggered and the On/Off module is not turning on per the programmed ISY.  Noticed that on "Query" (under "Options" , "Device Options" on the ISY) that the "Trigger Reverse" is checked.  Could that have something to do with the fact the On/Off module is not being turned on?
Forgot to mention that I am using this with an I/O unit....
Edited by jmac
