Problem With 5-Button KPL
smokegrub
A program executing when a button is pressed has stopped working. I checked the KPL in the Device Tree and it had the red circle logo adjacent to all 5 nodes. I control-clicked the first node intending to do a Query but the Query option was not available. I then tried a soft reset without success. The KPL nodes are in a folder and when I tried to remove them from the folder in preparation to delete them I was unable. I then tried to delete the folder itself and could not. All the buttons on the KPL but one still perform their intended purpose. I am stuck. Any help would be appreciated.
The Red circle indicates the KPL is "Disabled" which is why there is no Query option.  Right click on Primary node and select "Enable"
Now you can redefine all the Scene/Program connections.   Would have been easier to Enable device.  A device is not marked Disabled because the ISY encountered an error.   That could lead to a Red ! but not Disable.  The Disable option was clicked (by accident ?) .
Yesterday, I disabled several devices and a couple of scenes plus 1 program. I must have done something accidentally. Nevertheless, you have further educated me with the meaning of this icon and the proper step to take to address it.
When I tried a factory reset and relinking, it did not work. As I checked things out, I noticed the KPL had reappeared in the Device Tree along with the disabled icons. I deleted these from the Device Tree and relinked the KPL. After a bit of work all is up and running again. Thanks, Stu.
      377.2k
