AT&T to end email-to-text ×
ISY994i and Remotelinc linking
Like others, I was having trouble linking a 2440 Remotelinc to the ISY.  I kept placing the 2440 right next to various access points with no success.  Sometimes it would register, but the linking process would never complete.  I thought that perhaps the Remotelinc was putting out too strong a signal for the access point, so I tried increasing the distance between the devices and it worked perfectly.  I compare this to getting a microphone too close to a speaker and the resultant feedback (Think Jimi Hendrix).  This worked for me anyway.
All,
This is consistent with other INSTEON wireless devices, frankly consistent with MOST wireless devices (INSTEON or not.)  In a recent installation in a commercial building I was assisting a dealer with, we found that after adding a device to the network, you need to move it away from the PLM before adding another. Of course it took us hours to realize that having 150 devices on our bench all communicating with the PLM at once was a bad thing!
Once the devices were installed, all was well, but putting them aside in a box after pairing made the setup & installation go much smoother.
All seven of my RemoteLincs (2440) always indicate that they are ready to write, that is [1011>. None of my four Mini Remotes show that. nor do any other batter power devices. But, all work.
Likely means that you have made changes to scenes that these are controllers for.  Put one of the 2440's in linking mode and select Write Updates in the console for that unit.  Does the 1011 go away?  If so, repeat one at a time with the remaining 6.
-Xathros
Nope. I've tried both restore and write updates many, many, many times over the last six or so months. There have been no changes to their scenes. This is consistent for all seven RemoteLincs. All but one are v.35, the other is v.80. On occasion, the 1011 disappears, but that's always short lived. The paddles function as they should, so does dim and bright.
Hi Michel,
All buttons are scene controllers only (i.e., not in any program) except for two buttons on one RemoteLinc . On that RemoteLinc, one programmed button closes garage 1 door (On) or garage 2 door (Off). The other programmed button calls a network resource.
Stu
Hi Stu,
Thank you and I understand. I apologize for not being clear. I am specifically asking whether or not you use the Adjust Scene command in programs to change scene behavior based on certain conditions such as time of day.
Do the 1011 icons ever go away and then reappear without your intervention?
Hi Michel,
None of my programs use the Adjust Scene command-at all-none. I log in to the ISY every day. On very few occasions, the 1011 did not appear at log-in on some RemoteLincs. It is not consistent, doesn't last and is quite rare.
I just tried Restore Device on one of the RemoteLincs. The 1011 cleared--on a different RemoteLinc.
Stu
BTW, we had another All On. I'll report on the All On thread when I have more information.
I have had a similar issue a while ago with one of my Remotelincs too. It would work but I could not write updates to it. I messed around with it for a bit and then decided to try to remove it and add it back in. Everything I did would not let me communicate to add it back it in. I am thinking that a firmware update 'broke' it but got tired of trying it and retired it to a box for now. I replaced the functions with a mini remote without problems.
Dwight
I've been happily ignoring my RemoteLinc 2440 for months.  It was working when it went into the drawer.
Fished it out this afternoon, batteries were dead -- replaced them, and tried to use it.  No go, so I tried a "restore" on my ISY 944i.
Couldn't communicate at all.
So, I reset the RemoteLinc, deleted it from the ISY, and tried to re-add it.  Again no go.
Replaced the batteries in the RemoteLinc, reset it again, and tried several more times to add it.  Again no go.
Tried putting in various places in the house - right beside an access point, on the counter some 20 feet away from the nearest RF device, in a metal box, as well as from the chair that it was initially set up from -- nothing made any difference; the ISY cannot talk to it at all.
Restarted ISY.  Repeated above.  No change.
Here's the diagnostic info - nothing to see really, no replies:
Fri 01/16/2015 06:26:37 PM : [11 c5 7d    ] Added to list of devices to link to ISY
Fri 01/16/2015 06:26:37 PM : [iNST-TX-I1  ] 02 62 11 C5 7D 0F 0D 00
Fri 01/16/2015 06:26:37 PM : [iNST-ACK    ] 02 62 11.C5.7D 0F 0D 00 06                 (00)
Fri 01/16/2015 06:26:46 PM : [iNST-TX-I1  ] 02 62 11 C5 7D 0F 0D 00
Fri 01/16/2015 06:26:46 PM : [iNST-ACK    ] 02 62 11.C5.7D 0F 0D 00 06                 (00)
Fri 01/16/2015 06:26:55 PM : [iNST-TX-I1  ] 02 62 11 C5 7D 0F 0D 00
Fri 01/16/2015 06:26:55 PM : [iNST-ACK    ] 02 62 11.C5.7D 0F 0D 00 06                 (00)
Fri 01/16/2015 06:26:59 PM : [11 C5 7D 0  ] Failed to add device, reason 3
Fri 01/16/2015 06:26:59 PM : [All         ] Writing 0 bytes to devices
The ISY is running 4.2.18
I'll try upgrading to the latest 4.2 version later this weekend, I guess.  But it sure seems that there's something not right here.
-Mike
Not sure if this will add anything to the process.   Here is a RemoteLinc with v.35 firmware being added to 4.2.22. The DIM/BRIGHT buttons were used to put the RemoteLinc into linking mode.   New INSTEON Device was used, entering Insteon address, name of choice and Auto Discover.
Fri 01/16/2015 07:41:54 PM : [11 ad cf    ] Added to list of devices to link to ISY
Fri 01/16/2015 07:41:54 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 0D 00
Fri 01/16/2015 07:41:54 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 0D 00 06                 (00)
Fri 01/16/2015 07:41:54 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 0D 01           (01)
Fri 01/16/2015 07:41:54 PM : [std-Direct Ack] 11.AD.CF-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 01/16/2015 07:41:54 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 10 00
Fri 01/16/2015 07:41:54 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 10 00 06          ID-REQ (00)
Fri 01/16/2015 07:41:54 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 10 00    ID-REQ (00)
Fri 01/16/2015 07:41:54 PM : [iNST-SRX    ] 02 50 11.AD.CF 00.05.35 8B 01 00           (00)
Fri 01/16/2015 07:41:54 PM : [std-Broadcast] 11.AD.CF-->00.05.35, Max Hops=3, Hops Left=2
Fri 01/16/2015 07:41:54 PM : [11 AD CF 0  ] Calibrating engine version
Fri 01/16/2015 07:41:54 PM : [11 AD CF 0  ] May not fully support i2, reverting to i1
Fri 01/16/2015 07:41:54 PM : [11 AD CF 0  ] Using Database Link Table offset 0x0FF8 (reported 0x0000)
Fri 01/16/2015 07:41:55 PM : [11 AD CF 1  ] Start : Adding device to ISY
Fri 01/16/2015 07:41:55 PM : [11 AD CF 1  ] Finish : Adding device to ISY was Successful
Fri 01/16/2015 07:41:55 PM : [11 AD CF 1  ] Link    0 : 0FF8 [E20122800B010001] Saving  [E20122800B010001]
Fri 01/16/2015 07:41:55 PM : [11 AD CF 2  ] Start : Adding device to ISY
Fri 01/16/2015 07:41:55 PM : [11 AD CF 2  ] Finish : Adding device to ISY was Successful
Fri 01/16/2015 07:41:55 PM : [11 AD CF 2  ] Link    1 : 0FF0 [E20222800B010002] Saving  [E20222800B010002]
Fri 01/16/2015 07:41:55 PM : [11 AD CF 3  ] Start : Adding device to ISY
Fri 01/16/2015 07:41:55 PM : [11 AD CF 3  ] Finish : Adding device to ISY was Successful
Fri 01/16/2015 07:41:56 PM : [11 AD CF 3  ] Link    2 : 0FE8 [E20322800B010003] Saving  [E20322800B010003]
Fri 01/16/2015 07:41:56 PM : [11 AD CF 4  ] Start : Adding device to ISY
Fri 01/16/2015 07:41:56 PM : [11 AD CF 4  ] Finish : Adding device to ISY was Successful
Fri 01/16/2015 07:41:56 PM : [11 AD CF 4  ] Link    3 : 0FE0 [E20422800B010004] Saving  [E20422800B010004]
Fri 01/16/2015 07:41:56 PM : [11 AD CF 5  ] Start : Adding device to ISY
Fri 01/16/2015 07:41:56 PM : [11 AD CF 5  ] Finish : Adding device to ISY was Successful
Fri 01/16/2015 07:41:56 PM : [11 AD CF 5  ] Link    4 : 0FD8 [E20522800B010005] Saving  [E20522800B010005]
Fri 01/16/2015 07:41:56 PM : [11 AD CF 6  ] Start : Adding device to ISY
Fri 01/16/2015 07:41:56 PM : [11 AD CF 6  ] Finish : Adding device to ISY was Successful
Fri 01/16/2015 07:41:57 PM : [11 AD CF 6  ] Link    5 : 0FD0 [E20622800B010006] Saving  [E20622800B010006]
Fri 01/16/2015 07:41:57 PM : [11 AD CF 0  ] Successfully added device
Fri 01/16/2015 07:41:58 PM : [All         ] Writing 48 bytes to devices
Fri 01/16/2015 07:41:58 PM : [11 AD CF 1  ] Link    0 : 0FF8 [E20122800B010001] Writing [E20122800B010001]
Fri 01/16/2015 07:41:58 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 28 0F
Fri 01/16/2015 07:41:58 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 28 0F 06          SET-MSB(0F)
Fri 01/16/2015 07:41:59 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 28 0F    SET-MSB(0F)
Fri 01/16/2015 07:41:59 PM : [std-Direct Ack] 11.AD.CF-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 01/16/2015 07:41:59 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 2B F8
Fri 01/16/2015 07:41:59 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 2B F8 06          PEEK   (F8)
Fri 01/16/2015 07:41:59 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 2B E2    PEEK   (E2)
Fri 01/16/2015 07:41:59 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 28 0F
Fri 01/16/2015 07:41:59 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 28 0F 06          SET-MSB(0F)
Fri 01/16/2015 07:42:00 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 28 0F    SET-MSB(0F)
Fri 01/16/2015 07:42:00 PM : [std-Direct Ack] 11.AD.CF-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 01/16/2015 07:42:00 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 2B F9
Fri 01/16/2015 07:42:00 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 2B F9 06          PEEK   (F9)
Fri 01/16/2015 07:42:00 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 2B 01    PEEK   (01)
Fri 01/16/2015 07:42:00 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 28 0F
Fri 01/16/2015 07:42:00 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 28 0F 06          SET-MSB(0F)
Fri 01/16/2015 07:42:01 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 28 0F    SET-MSB(0F)
Fri 01/16/2015 07:42:01 PM : [std-Direct Ack] 11.AD.CF-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 01/16/2015 07:42:01 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 2B FA
Fri 01/16/2015 07:42:01 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 2B FA 06          PEEK   (FA)
Fri 01/16/2015 07:42:01 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 2B 22    PEEK   (22)
Fri 01/16/2015 07:42:01 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 28 0F
Fri 01/16/2015 07:42:01 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 28 0F 06          SET-MSB(0F)
Fri 01/16/2015 07:42:02 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 28 0F    SET-MSB(0F)
Fri 01/16/2015 07:42:02 PM : [std-Direct Ack] 11.AD.CF-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 01/16/2015 07:42:02 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 2B FB
Fri 01/16/2015 07:42:02 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 2B FB 06          PEEK   (FB)
Fri 01/16/2015 07:42:02 PM : [iNST-ERX    ] 02 51 13 AD CF 22 80 0B 11 41 8F 5E A6 72 00 03 FF 00 00 00 00 00 00 00 59
Fri 01/16/2015 07:42:02 PM : [Ext-Direct  ] 13.AD.CF-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Fri 01/16/2015 07:42:02 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 2B 80    PEEK   (80)
Fri 01/16/2015 07:42:02 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 28 0F
Fri 01/16/2015 07:42:02 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 28 0F 06          SET-MSB(0F)
Fri 01/16/2015 07:42:03 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 28 0F    SET-MSB(0F)
Fri 01/16/2015 07:42:03 PM : [std-Direct Ack] 11.AD.CF-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 01/16/2015 07:42:03 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 2B FC
Fri 01/16/2015 07:42:03 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 2B FC 06          PEEK   (FC)
Fri 01/16/2015 07:42:04 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 2B 0B    PEEK   (0B)
Fri 01/16/2015 07:42:04 PM : [std-Direct Ack] 11.AD.CF-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 01/16/2015 07:42:04 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 28 0F
Fri 01/16/2015 07:42:04 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 28 0F 06          SET-MSB(0F)
Fri 01/16/2015 07:42:04 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 28 0F    SET-MSB(0F)
Fri 01/16/2015 07:42:04 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 2B FD
Fri 01/16/2015 07:42:04 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 2B FD 06          PEEK   (FD)
Fri 01/16/2015 07:42:05 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 2B FF    PEEK   (FF)
Fri 01/16/2015 07:42:05 PM : [std-Direct Ack] 11.AD.CF-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 01/16/2015 07:42:05 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 29 01
Fri 01/16/2015 07:42:05 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 29 01 06          POKE   (01)
Fri 01/16/2015 07:42:05 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 29 01    POKE   (01)
Fri 01/16/2015 07:42:05 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 2B FE
Fri 01/16/2015 07:42:05 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 2B FE 06          PEEK   (FE)
Fri 01/16/2015 07:42:06 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 2B 00    PEEK   (00)
Fri 01/16/2015 07:42:06 PM : [std-Direct Ack] 11.AD.CF-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 01/16/2015 07:42:06 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 28 0F
Fri 01/16/2015 07:42:06 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 28 0F 06          SET-MSB(0F)
Fri 01/16/2015 07:42:06 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 28 0F    SET-MSB(0F)
Fri 01/16/2015 07:42:06 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 2B FF
Fri 01/16/2015 07:42:06 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 2B FF 06          PEEK   (FF)
Fri 01/16/2015 07:42:07 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 2B 01    PEEK   (01)
Fri 01/16/2015 07:42:07 PM : [std-Direct Ack] 11.AD.CF-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 01/16/2015 07:42:07 PM : [MNG-LNK-RSP ] 02 6F 41 A2 01 11 AD CF 00 05 35 15
Fri 01/16/2015 07:42:07 PM : [PLM         ] Group   1 : Writing Responder Link matching [11 AD CF 1  ] Link    0 : 0FF8 [E20122800B010001]
Fri 01/16/2015 07:42:07 PM : [11 AD CF 1  ] Link    1 : 0FF0 [E20222800B010002] Writing [E20222800B010002]
Fri 01/16/2015 07:42:07 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 28 0F
Fri 01/16/2015 07:42:07 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 28 0F 06          SET-MSB(0F)
Fri 01/16/2015 07:42:08 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 28 0F    SET-MSB(0F)
Fri 01/16/2015 07:42:08 PM : [std-Direct Ack] 11.AD.CF-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 01/16/2015 07:42:08 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 2B F0
Fri 01/16/2015 07:42:08 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 2B F0 06          PEEK   (F0)
Fri 01/16/2015 07:42:08 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 2B 62    PEEK   (62)
Fri 01/16/2015 07:42:08 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 29 E2
Fri 01/16/2015 07:42:08 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 29 E2 06          POKE   (E2)
Fri 01/16/2015 07:42:09 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 29 E2    POKE   (E2)
Fri 01/16/2015 07:42:09 PM : [std-Direct Ack] 11.AD.CF-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 01/16/2015 07:42:09 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 2B F1
Fri 01/16/2015 07:42:09 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 2B F1 06          PEEK   (F1)
Fri 01/16/2015 07:42:09 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 2B 02    PEEK   (02)
Fri 01/16/2015 07:42:09 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 28 0F
Fri 01/16/2015 07:42:09 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 28 0F 06          SET-MSB(0F)
Fri 01/16/2015 07:42:10 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 28 0F    SET-MSB(0F)
Fri 01/16/2015 07:42:10 PM : [std-Direct Ack] 11.AD.CF-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 01/16/2015 07:42:10 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 2B F2
Fri 01/16/2015 07:42:10 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 2B F2 06          PEEK   (F2)
Fri 01/16/2015 07:42:10 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 2B 22    PEEK   (22)
Fri 01/16/2015 07:42:10 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 28 0F
Fri 01/16/2015 07:42:10 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 28 0F 06          SET-MSB(0F)
Fri 01/16/2015 07:42:11 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 28 0F    SET-MSB(0F)
Fri 01/16/2015 07:42:11 PM : [std-Direct Ack] 11.AD.CF-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 01/16/2015 07:42:11 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 2B F3
Fri 01/16/2015 07:42:11 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 2B F3 06          PEEK   (F3)
Fri 01/16/2015 07:42:11 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 2B 80    PEEK   (80)
Fri 01/16/2015 07:42:11 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 28 0F
Fri 01/16/2015 07:42:11 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 28 0F 06          SET-MSB(0F)
Fri 01/16/2015 07:42:12 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 28 0F    SET-MSB(0F)
Fri 01/16/2015 07:42:12 PM : [std-Direct Ack] 11.AD.CF-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 01/16/2015 07:42:12 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 2B F4
Fri 01/16/2015 07:42:12 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 2B F4 06          PEEK   (F4)
Fri 01/16/2015 07:42:12 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 2B 0B    PEEK   (0B)
Fri 01/16/2015 07:42:12 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 28 0F
Fri 01/16/2015 07:42:12 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 28 0F 06          SET-MSB(0F)
Fri 01/16/2015 07:42:13 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 28 0F    SET-MSB(0F)
Fri 01/16/2015 07:42:13 PM : [std-Direct Ack] 11.AD.CF-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 01/16/2015 07:42:13 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 2B F5
Fri 01/16/2015 07:42:13 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 2B F5 06          PEEK   (F5)
Fri 01/16/2015 07:42:13 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 2B FF    PEEK   (FF)
Fri 01/16/2015 07:42:13 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 29 01
Fri 01/16/2015 07:42:13 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 29 01 06          POKE   (01)
Fri 01/16/2015 07:42:14 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 29 01    POKE   (01)
Fri 01/16/2015 07:42:14 PM : [std-Direct Ack] 11.AD.CF-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 01/16/2015 07:42:14 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 2B F6
Fri 01/16/2015 07:42:14 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 2B F6 06          PEEK   (F6)
Fri 01/16/2015 07:42:14 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 2B 00    PEEK   (00)
Fri 01/16/2015 07:42:14 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 28 0F
Fri 01/16/2015 07:42:14 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 28 0F 06          SET-MSB(0F)
Fri 01/16/2015 07:42:15 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 28 0F    SET-MSB(0F)
Fri 01/16/2015 07:42:15 PM : [std-Direct Ack] 11.AD.CF-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 01/16/2015 07:42:15 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 2B F7
Fri 01/16/2015 07:42:15 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 2B F7 06          PEEK   (F7)
Fri 01/16/2015 07:42:15 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 2B 02    PEEK   (02)
Fri 01/16/2015 07:42:16 PM : [MNG-LNK-RSP ] 02 6F 41 A2 02 11 AD CF 00 05 35 06
Fri 01/16/2015 07:42:16 PM : [PLM         ] Group   2 : Writing Responder Link matching [11 AD CF 1  ] Link    1 : 0FF0 [E20222800B010002]
Fri 01/16/2015 07:42:16 PM : [11 AD CF 1  ] Link    2 : 0FE8 [E20322800B010003] Writing [E20322800B010003]
Fri 01/16/2015 07:42:16 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 28 0F
Fri 01/16/2015 07:42:16 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 28 0F 06          SET-MSB(0F)
Fri 01/16/2015 07:42:16 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 28 0F    SET-MSB(0F)
Fri 01/16/2015 07:42:16 PM : [std-Direct Ack] 11.AD.CF-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 01/16/2015 07:42:16 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 2B E8
Fri 01/16/2015 07:42:16 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 2B E8 06          PEEK   (E8)
Fri 01/16/2015 07:42:17 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 2B 62    PEEK   (62)
Fri 01/16/2015 07:42:17 PM : [std-Direct Ack] 11.AD.CF-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 01/16/2015 07:42:17 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 29 E2
Fri 01/16/2015 07:42:17 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 29 E2 06          POKE   (E2)
Fri 01/16/2015 07:42:17 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 29 E2    POKE   (E2)
Fri 01/16/2015 07:42:17 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 2B E9
Fri 01/16/2015 07:42:17 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 2B E9 06          PEEK   (E9)
Fri 01/16/2015 07:42:18 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 2B 03    PEEK   (03)
Fri 01/16/2015 07:42:18 PM : [std-Direct Ack] 11.AD.CF-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 01/16/2015 07:42:18 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 28 0F
Fri 01/16/2015 07:42:18 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 28 0F 06          SET-MSB(0F)
Fri 01/16/2015 07:42:18 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 28 0F    SET-MSB(0F)
Fri 01/16/2015 07:42:18 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 2B EA
Fri 01/16/2015 07:42:18 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 21 34 1F           (1F)
Fri 01/16/2015 07:42:18 PM : [std-Direct Ack] 11.AD.CF-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Fri 01/16/2015 07:42:18 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 2B EA 06          PEEK   (EA)
Fri 01/16/2015 07:42:19 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 2B 22    PEEK   (22)
Fri 01/16/2015 07:42:19 PM : [std-Direct Ack] 11.AD.CF-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 01/16/2015 07:42:19 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 28 0F
Fri 01/16/2015 07:42:19 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 28 0F 06          SET-MSB(0F)
Fri 01/16/2015 07:42:19 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 20 D4 E2           (E2)
Fri 01/16/2015 07:42:19 PM : [std-Direct Ack] 11.AD.CF-->ISY/PLM Group=0, Max Hops=0, Hops Left=0
Fri 01/16/2015 07:42:19 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 28 0F    SET-MSB(0F)
Fri 01/16/2015 07:42:19 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 2B EB
Fri 01/16/2015 07:42:19 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 2B EB 06          PEEK   (EB)
Fri 01/16/2015 07:42:20 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 2B 80    PEEK   (80)
Fri 01/16/2015 07:42:20 PM : [std-Direct Ack] 11.AD.CF-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 01/16/2015 07:42:20 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 28 0F
Fri 01/16/2015 07:42:20 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 28 0F 06          SET-MSB(0F)
Fri 01/16/2015 07:42:20 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 28 0F    SET-MSB(0F)
Fri 01/16/2015 07:42:20 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 2B EC
Fri 01/16/2015 07:42:20 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 2B EC 06          PEEK   (EC)
Fri 01/16/2015 07:42:21 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 2B 0B    PEEK   (0B)
Fri 01/16/2015 07:42:21 PM : [std-Direct Ack] 11.AD.CF-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 01/16/2015 07:42:21 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 28 0F
Fri 01/16/2015 07:42:21 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 28 0F 06          SET-MSB(0F)
Fri 01/16/2015 07:42:21 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 28 0F    SET-MSB(0F)
Fri 01/16/2015 07:42:21 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 2B ED
Fri 01/16/2015 07:42:21 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 2B ED 06          PEEK   (ED)
Fri 01/16/2015 07:42:22 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 2B FF    PEEK   (FF)
Fri 01/16/2015 07:42:22 PM : [std-Direct Ack] 11.AD.CF-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 01/16/2015 07:42:22 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 29 01
Fri 01/16/2015 07:42:22 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 29 01 06          POKE   (01)
Fri 01/16/2015 07:42:22 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 29 01    POKE   (01)
Fri 01/16/2015 07:42:22 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 2B EE
Fri 01/16/2015 07:42:22 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 2B EE 06          PEEK   (EE)
Fri 01/16/2015 07:42:23 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 2B 00    PEEK   (00)
Fri 01/16/2015 07:42:23 PM : [std-Direct Ack] 11.AD.CF-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 01/16/2015 07:42:23 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 28 0F
Fri 01/16/2015 07:42:23 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 28 0F 06          SET-MSB(0F)
Fri 01/16/2015 07:42:23 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 28 0F    SET-MSB(0F)
Fri 01/16/2015 07:42:23 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 2B EF
Fri 01/16/2015 07:42:23 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 2B EF 06          PEEK   (EF)
Fri 01/16/2015 07:42:24 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 2B 03    PEEK   (03)
Fri 01/16/2015 07:42:24 PM : [std-Direct Ack] 11.AD.CF-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 01/16/2015 07:42:24 PM : [MNG-LNK-RSP ] 02 6F 41 A2 03 11 00 05 35 05 35 06 : : Unexpected, ignored (6F)
Fri 01/16/2015 07:42:26 PM : [iNST-SRX    ] 02 50 21.7A.CC 00.00.04 CB 11 04    LTONRR (04)
Fri 01/16/2015 07:42:26 PM : [std-Group   ] 21.7A.CC-->Group=4, Max Hops=3, Hops Left=2
Fri 01/16/2015 07:42:26 PM : [D2D EVENT   ] Event [21 7A CC 4] [DON] [4] uom=0 prec=-1
Fri 01/16/2015 07:42:26 PM : [  21 7A CC 4]      DON   4
Fri 01/16/2015 07:42:26 PM : [D2D-CMP 0044] CTL [21 7A CC 4] DON op=1 Event(val=4 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> true
Fri 01/16/2015 07:42:28 PM : [iNST-SRX    ] 02 50 21.7A.CC 00.00.04 CB 11 04    LTONRR (04)
Fri 01/16/2015 07:42:28 PM : [std-Group   ] 21.7A.CC-->Group=4, Max Hops=3, Hops Left=2
Fri 01/16/2015 07:42:28 PM : [iNST-DUP    ] Previous message ignored.
Fri 01/16/2015 07:42:29 PM : [iNST-SRX    ] 02 50 21.7A.CC 22.80.0B 41 11 04    LTONRR (04)
Fri 01/16/2015 07:42:29 PM : [std-Cleanup ] 21.7A.CC-->ISY/PLM Group=4, Max Hops=1, Hops Left=0
Fri 01/16/2015 07:42:29 PM : [iNST-DUP    ] Previous message ignored.
Fri 01/16/2015 07:42:29 PM : [iNST-SRX    ] 02 50 21.7A.CC 11.01.04 CB 06 00           (00)
Fri 01/16/2015 07:42:29 PM : [std-Group   ] 21.7A.CC-->11.01.04, Max Hops=3, Hops Left=2
Fri 01/16/2015 07:42:29 PM : [iNST-INFO   ] Previous message ignored.
Fri 01/16/2015 07:42:30 PM : [iNST-SRX    ] 02 50 21.7A.CC 11.01.04 CB 06 00           (00)
Fri 01/16/2015 07:42:30 PM : [std-Group   ] 21.7A.CC-->11.01.04, Max Hops=3, Hops Left=2
Fri 01/16/2015 07:42:30 PM : [iNST-INFO   ] Previous message ignored.
Fri 01/16/2015 07:42:39 PM : [MNG-LNK-RSP ] 02 6F 41 A2 03 11 AD CF 00 05 35 06
Fri 01/16/2015 07:42:39 PM : [PLM         ] Group   3 : Writing Responder Link matching [11 AD CF 1  ] Link    2 : 0FE8 [E20322800B010003]
Fri 01/16/2015 07:42:39 PM : [11 AD CF 1  ] Link    3 : 0FE0 [E20422800B010004] Writing [E20422800B010004]
Fri 01/16/2015 07:42:39 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 28 0F
Fri 01/16/2015 07:42:39 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 28 0F 06          SET-MSB(0F)
Fri 01/16/2015 07:42:40 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 28 0F    SET-MSB(0F)
Fri 01/16/2015 07:42:40 PM : [std-Direct Ack] 11.AD.CF-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 01/16/2015 07:42:40 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 2B E0
Fri 01/16/2015 07:42:40 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 2B E0 06          PEEK   (E0)
Fri 01/16/2015 07:42:40 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 2B 62    PEEK   (62)
Fri 01/16/2015 07:42:40 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 29 E2
Fri 01/16/2015 07:42:40 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 29 E2 06          POKE   (E2)
Fri 01/16/2015 07:42:41 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 27 29 E2    POKE   (E2)
Fri 01/16/2015 07:42:41 PM : [std-Direct Ack] 11.AD.CF-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Fri 01/16/2015 07:42:41 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 2B E1
Fri 01/16/2015 07:42:41 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 2B E1 06          PEEK   (E1)
Fri 01/16/2015 07:42:42 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 2B 04    PEEK   (04)
Fri 01/16/2015 07:42:42 PM : [std-Direct Ack] 11.AD.CF-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 01/16/2015 07:42:42 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 28 0F
Fri 01/16/2015 07:42:42 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 28 0F 06          SET-MSB(0F)
Fri 01/16/2015 07:42:42 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 28 0F    SET-MSB(0F)
Fri 01/16/2015 07:42:42 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 2B E2
Fri 01/16/2015 07:42:42 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 2B E2 06          PEEK   (E2)
Fri 01/16/2015 07:42:43 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 2B 22    PEEK   (22)
Fri 01/16/2015 07:42:43 PM : [std-Direct Ack] 11.AD.CF-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 01/16/2015 07:42:43 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 28 0F
Fri 01/16/2015 07:42:43 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 28 0F 06          SET-MSB(0F)
Fri 01/16/2015 07:42:43 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 28 0F    SET-MSB(0F)
Fri 01/16/2015 07:42:43 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 2B E3
Fri 01/16/2015 07:42:43 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 2B E3 06          PEEK   (E3)
Fri 01/16/2015 07:42:44 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 2B 80    PEEK   (80)
Fri 01/16/2015 07:42:44 PM : [std-Direct Ack] 11.AD.CF-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 01/16/2015 07:42:44 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 28 0F
Fri 01/16/2015 07:42:44 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 28 0F 06          SET-MSB(0F)
Fri 01/16/2015 07:42:44 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 23 2B 80    PEEK   (80)
Fri 01/16/2015 07:42:44 PM : [std-Direct Ack] 11.AD.CF-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Fri 01/16/2015 07:42:44 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 28 0F    SET-MSB(0F)
Fri 01/16/2015 07:42:44 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 2B E4
Fri 01/16/2015 07:42:44 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 2B E4 06          PEEK   (E4)
Fri 01/16/2015 07:42:45 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 2B 0B    PEEK   (0B)
Fri 01/16/2015 07:42:45 PM : [std-Direct Ack] 11.AD.CF-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 01/16/2015 07:42:45 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 28 0F
Fri 01/16/2015 07:42:45 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 28 0F 06          SET-MSB(0F)
Fri 01/16/2015 07:42:45 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 28 0F    SET-MSB(0F)
Fri 01/16/2015 07:42:45 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 2B E5
Fri 01/16/2015 07:42:45 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 2B E5 06          PEEK   (E5)
Fri 01/16/2015 07:42:46 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 2B FF    PEEK   (FF)
Fri 01/16/2015 07:42:46 PM : [std-Direct Ack] 11.AD.CF-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 01/16/2015 07:42:46 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 29 01
Fri 01/16/2015 07:42:46 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 29 01 06          POKE   (01)
Fri 01/16/2015 07:42:46 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 29 01    POKE   (01)
Fri 01/16/2015 07:42:46 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 2B E6
Fri 01/16/2015 07:42:46 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 2B E6 06          PEEK   (E6)
Fri 01/16/2015 07:42:47 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 2B 00    PEEK   (00)
Fri 01/16/2015 07:42:47 PM : [std-Direct Ack] 11.AD.CF-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 01/16/2015 07:42:47 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 28 0F
Fri 01/16/2015 07:42:47 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 28 0F 06          SET-MSB(0F)
Fri 01/16/2015 07:42:47 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 28 0F    SET-MSB(0F)
Fri 01/16/2015 07:42:47 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 2B E7
Fri 01/16/2015 07:42:47 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 2B E7 06          PEEK   (E7)
Fri 01/16/2015 07:42:48 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 2B 04    PEEK   (04)
Fri 01/16/2015 07:42:48 PM : [std-Direct Ack] 11.AD.CF-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 01/16/2015 07:42:48 PM : [MNG-LNK-RSP ] 02 6F 41 A2 04 11 AD CF 00 05 35 06
Fri 01/16/2015 07:42:48 PM : [PLM         ] Group   4 : Writing Responder Link matching [11 AD CF 1  ] Link    3 : 0FE0 [E20422800B010004]
Fri 01/16/2015 07:42:48 PM : [11 AD CF 1  ] Link    4 : 0FD8 [E20522800B010005] Writing [E20522800B010005]
Fri 01/16/2015 07:42:48 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 28 0F
Fri 01/16/2015 07:42:48 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 28 0F 06          SET-MSB(0F)
Fri 01/16/2015 07:42:49 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 28 0F    SET-MSB(0F)
Fri 01/16/2015 07:42:49 PM : [std-Direct Ack] 11.AD.CF-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 01/16/2015 07:42:49 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 2B D8
Fri 01/16/2015 07:42:49 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 2B D8 06          PEEK   (D8)
Fri 01/16/2015 07:42:49 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 2B 62    PEEK   (62)
Fri 01/16/2015 07:42:49 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 29 E2
Fri 01/16/2015 07:42:49 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 29 E2 06          POKE   (E2)
Fri 01/16/2015 07:42:50 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 29 E2    POKE   (E2)
Fri 01/16/2015 07:42:50 PM : [std-Direct Ack] 11.AD.CF-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 01/16/2015 07:42:50 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 2B D9
Fri 01/16/2015 07:42:50 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 2B D9 06          PEEK   (D9)
Fri 01/16/2015 07:42:50 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 2B 05    PEEK   (05)
Fri 01/16/2015 07:42:50 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 28 0F
Fri 01/16/2015 07:42:50 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 28 0F 06          SET-MSB(0F)
Fri 01/16/2015 07:42:51 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 28 0F    SET-MSB(0F)
Fri 01/16/2015 07:42:51 PM : [std-Direct Ack] 11.AD.CF-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 01/16/2015 07:42:51 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 2B DA
Fri 01/16/2015 07:42:51 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 2B DA 06          PEEK   (DA)
Fri 01/16/2015 07:42:51 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 2B 22    PEEK   (22)
Fri 01/16/2015 07:42:51 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 28 0F
Fri 01/16/2015 07:42:51 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 28 0F 06          SET-MSB(0F)
Fri 01/16/2015 07:42:52 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 28 0F    SET-MSB(0F)
Fri 01/16/2015 07:42:52 PM : [std-Direct Ack] 11.AD.CF-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 01/16/2015 07:42:52 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 2B DB
Fri 01/16/2015 07:42:52 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 2B DB 06          PEEK   (DB)
Fri 01/16/2015 07:42:52 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 2B 80    PEEK   (80)
Fri 01/16/2015 07:42:52 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 28 0F
Fri 01/16/2015 07:42:52 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 28 0F 06          SET-MSB(0F)
Fri 01/16/2015 07:42:53 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 28 0F    SET-MSB(0F)
Fri 01/16/2015 07:42:53 PM : [std-Direct Ack] 11.AD.CF-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 01/16/2015 07:42:53 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 2B DC
Fri 01/16/2015 07:42:53 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 2B DC 06          PEEK   (DC)
Fri 01/16/2015 07:42:53 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 2B 0B    PEEK   (0B)
Fri 01/16/2015 07:42:53 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 28 0F
Fri 01/16/2015 07:42:53 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 28 0F 06          SET-MSB(0F)
Fri 01/16/2015 07:42:54 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 28 0F    SET-MSB(0F)
Fri 01/16/2015 07:42:54 PM : [std-Direct Ack] 11.AD.CF-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 01/16/2015 07:42:54 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 2B DD
Fri 01/16/2015 07:42:54 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 2B DD 06          PEEK   (DD)
Fri 01/16/2015 07:42:54 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 2B FF    PEEK   (FF)
Fri 01/16/2015 07:42:54 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 29 01
Fri 01/16/2015 07:42:54 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 29 01 06          POKE   (01)
Fri 01/16/2015 07:42:55 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 29 01    POKE   (01)
Fri 01/16/2015 07:42:55 PM : [std-Direct Ack] 11.AD.CF-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 01/16/2015 07:42:55 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 2B DE
Fri 01/16/2015 07:42:55 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 2B DE 06          PEEK   (DE)
Fri 01/16/2015 07:42:55 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 2B 00    PEEK   (00)
Fri 01/16/2015 07:42:55 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 28 0F
Fri 01/16/2015 07:42:55 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 28 0F 06          SET-MSB(0F)
Fri 01/16/2015 07:42:56 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 28 0F    SET-MSB(0F)
Fri 01/16/2015 07:42:56 PM : [std-Direct Ack] 11.AD.CF-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 01/16/2015 07:42:56 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 2B DF
Fri 01/16/2015 07:42:56 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 2B DF 06          PEEK   (DF)
Fri 01/16/2015 07:42:56 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 2B 05    PEEK   (05)
Fri 01/16/2015 07:42:57 PM : [MNG-LNK-RSP ] 02 6F 41 A2 05 11 AD CF 00 05 35 06
Fri 01/16/2015 07:42:57 PM : [PLM         ] Group   5 : Writing Responder Link matching [11 AD CF 1  ] Link    4 : 0FD8 [E20522800B010005]
Fri 01/16/2015 07:42:57 PM : [11 AD CF 1  ] Link    5 : 0FD0 [E20622800B010006] Writing [E20622800B010006]
Fri 01/16/2015 07:42:57 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 28 0F
Fri 01/16/2015 07:42:57 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 28 0F 06          SET-MSB(0F)
Fri 01/16/2015 07:42:57 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 28 0F    SET-MSB(0F)
Fri 01/16/2015 07:42:57 PM : [std-Direct Ack] 11.AD.CF-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 01/16/2015 07:42:57 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 2B D0
Fri 01/16/2015 07:42:57 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 2B D0 06          PEEK   (D0)
Fri 01/16/2015 07:42:58 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 2B 62    PEEK   (62)
Fri 01/16/2015 07:42:58 PM : [std-Direct Ack] 11.AD.CF-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 01/16/2015 07:42:58 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 29 E2
Fri 01/16/2015 07:42:58 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 29 E2 06          POKE   (E2)
Fri 01/16/2015 07:42:58 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 29 E2    POKE   (E2)
Fri 01/16/2015 07:42:58 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 2B D1
Fri 01/16/2015 07:42:59 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 2B D1 06          PEEK   (D1)
Fri 01/16/2015 07:42:59 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 2B 06    PEEK   (06)
Fri 01/16/2015 07:42:59 PM : [std-Direct Ack] 11.AD.CF-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 01/16/2015 07:42:59 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 28 0F
Fri 01/16/2015 07:42:59 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 28 0F 06          SET-MSB(0F)
Fri 01/16/2015 07:42:59 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 28 0F    SET-MSB(0F)
Fri 01/16/2015 07:42:59 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 2B D2
Fri 01/16/2015 07:42:59 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 2B D2 06          PEEK   (D2)
Fri 01/16/2015 07:43:00 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 2B 22    PEEK   (22)
Fri 01/16/2015 07:43:00 PM : [std-Direct Ack] 11.AD.CF-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 01/16/2015 07:43:00 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 28 0F
Fri 01/16/2015 07:43:00 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 28 0F 06          SET-MSB(0F)
Fri 01/16/2015 07:43:00 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 28 0F    SET-MSB(0F)
Fri 01/16/2015 07:43:00 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 2B D3
Fri 01/16/2015 07:43:01 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 2B D3 06          PEEK   (D3)
Fri 01/16/2015 07:43:01 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 2B 80    PEEK   (80)
Fri 01/16/2015 07:43:01 PM : [std-Direct Ack] 11.AD.CF-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 01/16/2015 07:43:01 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 28 0F
Fri 01/16/2015 07:43:01 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 28 0F 06          SET-MSB(0F)
Fri 01/16/2015 07:43:01 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 28 0F    SET-MSB(0F)
Fri 01/16/2015 07:43:01 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 2B D4
Fri 01/16/2015 07:43:02 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 2B D4 06          PEEK   (D4)
Fri 01/16/2015 07:43:02 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 2B 0B    PEEK   (0B)
Fri 01/16/2015 07:43:02 PM : [std-Direct Ack] 11.AD.CF-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 01/16/2015 07:43:02 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 28 0F
Fri 01/16/2015 07:43:02 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 28 0F 06          SET-MSB(0F)
Fri 01/16/2015 07:43:02 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 28 0F    SET-MSB(0F)
Fri 01/16/2015 07:43:02 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 2B D5
Fri 01/16/2015 07:43:03 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 2B D5 06          PEEK   (D5)
Fri 01/16/2015 07:43:03 PM : [iNST-ERX    ] 02 51 11 AD CF 22 80 0B 11 40 38 A7 7E E7 FC 91 46 B5 24 92 30 59 94 08 59
Fri 01/16/2015 07:43:03 PM : [Ext-Direct  ] 11.AD.CF-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Fri 01/16/2015 07:43:03 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 2B FF    PEEK   (FF)
Fri 01/16/2015 07:43:03 PM : [std-Direct Ack] 11.AD.CF-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 01/16/2015 07:43:03 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 29 01
Fri 01/16/2015 07:43:03 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 29 01 06          POKE   (01)
Fri 01/16/2015 07:43:04 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 29 01    POKE   (01)
Fri 01/16/2015 07:43:04 PM : [std-Direct Ack] 11.AD.CF-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 01/16/2015 07:43:04 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 2B D6
Fri 01/16/2015 07:43:04 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 2B D6 06          PEEK   (D6)
Fri 01/16/2015 07:43:04 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 2B 00    PEEK   (00)
Fri 01/16/2015 07:43:04 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 28 0F
Fri 01/16/2015 07:43:04 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 28 0F 06          SET-MSB(0F)
Fri 01/16/2015 07:43:05 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 28 0F    SET-MSB(0F)
Fri 01/16/2015 07:43:05 PM : [std-Direct Ack] 11.AD.CF-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 01/16/2015 07:43:05 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 2B D7
Fri 01/16/2015 07:43:05 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 2B D7 06          PEEK   (D7)
Fri 01/16/2015 07:43:05 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 2B 06    PEEK   (06)
Fri 01/16/2015 07:43:06 PM : [MNG-LNK-RSP ] 02 6F 41 A2 06 11 AD CF 00 05 35 06
Fri 01/16/2015 07:43:06 PM : [PLM         ] Group   6 : Writing Responder Link matching [11 AD CF 1  ] Link    5 : 0FD0 [E20622800B010006]
Fri 01/16/2015 07:43:06 PM : [11 AD CF 1  ] Link    6 : 0FC8 [0000000000000000] Writing [00..............]
Fri 01/16/2015 07:43:06 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 28 0F
Fri 01/16/2015 07:43:06 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 28 0F 06          SET-MSB(0F)
Fri 01/16/2015 07:43:06 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 28 0F    SET-MSB(0F)
Fri 01/16/2015 07:43:06 PM : [std-Direct Ack] 11.AD.CF-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 01/16/2015 07:43:06 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 2B C8
Fri 01/16/2015 07:43:06 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 2B C8 06          PEEK   (C8)
Fri 01/16/2015 07:43:07 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 2B 62    PEEK   (62)
Fri 01/16/2015 07:43:07 PM : [std-Direct Ack] 11.AD.CF-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 01/16/2015 07:43:07 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 29 00
Fri 01/16/2015 07:43:07 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 29 00 06          POKE   (00)
Fri 01/16/2015 07:43:07 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 29 00    POKE   (00)
Fri 01/16/2015 07:43:07 PM : [11 AD CF 1  ] Link    7 : 0FC0 : Writing High Water Byte
Fri 01/16/2015 07:43:07 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 28 0F
Fri 01/16/2015 07:43:07 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 28 0F 06          SET-MSB(0F)
Fri 01/16/2015 07:43:08 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 28 0F    SET-MSB(0F)
Fri 01/16/2015 07:43:08 PM : [std-Direct Ack] 11.AD.CF-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 01/16/2015 07:43:08 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 2B C0
Fri 01/16/2015 07:43:08 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 2B C0 06          PEEK   (C0)
Fri 01/16/2015 07:43:08 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 2B 62    PEEK   (62)
Fri 01/16/2015 07:43:08 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 29 00
Fri 01/16/2015 07:43:08 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 29 00 06          POKE   (00)
Fri 01/16/2015 07:43:09 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 29 00    POKE   (00)
Fri 01/16/2015 07:43:09 PM : [std-Direct Ack] 11.AD.CF-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 01/16/2015 07:43:09 PM : [11 AD CF 1  ] Link    8 : 0FB8 : Writing High Water Byte
Fri 01/16/2015 07:43:09 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 28 0F
Fri 01/16/2015 07:43:09 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 28 0F 06          SET-MSB(0F)
Fri 01/16/2015 07:43:09 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 28 0F    SET-MSB(0F)
Fri 01/16/2015 07:43:09 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 2B B8
Fri 01/16/2015 07:43:09 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 2B B8 06          PEEK   (B8)
Fri 01/16/2015 07:43:10 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 2B E2    PEEK   (E2)
Fri 01/16/2015 07:43:10 PM : [std-Direct Ack] 11.AD.CF-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 01/16/2015 07:43:10 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 29 00
Fri 01/16/2015 07:43:10 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 29 00 06          POKE   (00)
Fri 01/16/2015 07:43:11 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 29 00    POKE   (00)
Fri 01/16/2015 07:43:11 PM : [std-Direct Ack] 11.AD.CF-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 01/16/2015 07:43:11 PM : [11 AD CF 1  ] Link    9 : 0FB0 : Writing High Water Byte
Fri 01/16/2015 07:43:11 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 28 0F
Fri 01/16/2015 07:43:11 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 28 0F 06          SET-MSB(0F)
Fri 01/16/2015 07:43:11 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 28 0F    SET-MSB(0F)
Fri 01/16/2015 07:43:11 PM : [iNST-TX-I1  ] 02 62 11 AD CF 0F 2B B0
Fri 01/16/2015 07:43:11 PM : [iNST-ACK    ] 02 62 11.AD.CF 0F 2B B0 06          PEEK   (B0)
Fri 01/16/2015 07:43:12 PM : [iNST-SRX    ] 02 50 11.AD.CF 22.80.0B 2B 2B 00    PEEK   (00)
Fri 01/16/2015 07:43:12 PM : [std-Direct Ack] 11.AD.CF-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
  • 1 month later...
I just updated my old 2413s PLM (v1.B) purchase date 3/3/2013 with a new PLM with Firmware V 9e.7 Rev 2.0 due to the 2 year PLM failure problem. I am able to see and use all previous devices except for my 2 2440 RemoteLincs (V1.0). I also tried a rev 1.1 2440. I have 2 RemoteLInc 2 (2444a2) and they work fine. I have multiple montion sensors and they work fine. I have tried every option to make the 2440's work with the ISY. They will direct link to a responder and work fine. I am at Firmware level v4.0.5, UI v4.1.1.  I have been at this release for months.   When adding them to ISY I usually get Failed writing and it's always button 6 it is writing to.  The remoteLinc with send on and off signals, but I can never complete the device update status in ISY. So the one and only variable that changed was the new PLM. Any ideas???  Is there a newer version of the 2440? I can't find any information on the current version of the 2440. Are they obsolete??
4.0.5 is old firmware. 4.2.18 is the latest Official release with 4.2.23 being a candidate for the next Official release. As I posted earlier (post # 13) I added a RemoteLinc v.35 under 4.2.23 with no problem. The 2440 RemoteLinc is no longer being sold.
Try having the RemoteLinc near the 2413 PLM with a fresh set of batteries.
ISY 4.2.23
PLM v.2 9E
Six of my seven RemoteLincs are waiting to write updates [1011] no matter how many times I try.
I just added another RemoteLinc. It took about 4 or 5 tries. It, too, shows 1011
Hi Michel,
The RemoteLinc problem is not restricted to my Insteon network.
I added two 2440 Remotelincs to my setup as a test.
Hardware 1.0, firmware v.33 and hardware 1.2, firmware v.35.
Both added with no problems. I did have them right next to the 2413S PLM when I did it.
tedbusen
Can you post an Event Viewer at LEVEL 3 showing issue.   Although running 4.2.23 I can add a RemoteLinc without errors.
tedbusen
A point worth noting, it takes more than 200 Insteon messages that all flow as RF communication to define a RemoteLinc. That requires a good Insteon network to handle that many RF messages which is why folks have issues with the RemoteLinc. Even adding a RemoteLinc to a Scene requires some 35 Insteon RF messages which can be an issue many Insteon networks.
Hi Lee,
Here's my log from attempting to write updates to a RemoteLinc 2440, REV 1.2, v.35
ISY 994i PRO, 4.2.23; PLM v9E
Mon 02/23/2015 11:48:49 AM : [11 C5 51 1  ] Link    0 : 0FF8 [E201335FF6010001] Writing [E201335FF6010001]
Mon 02/23/2015 11:48:49 AM : [iNST-TX-I1  ] 02 62 11 C5 51 0F 28 0F
Mon 02/23/2015 11:48:49 AM : [iNST-ACK    ] 02 62 11.C5.51 0F 28 0F 06          SET-MSB(0F)
Mon 02/23/2015 11:48:51 AM : [iNST-SRX    ] 02 50 11.C5.51 33.5F.F6 27 28 0F    SET-MSB(0F)
Mon 02/23/2015 11:48:51 AM : [std-Direct Ack] 11.C5.51-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Mon 02/23/2015 11:48:51 AM : [iNST-TX-I1  ] 02 62 11 C5 51 0F 2B F8
Mon 02/23/2015 11:48:51 AM : [iNST-ACK    ] 02 62 11.C5.51 0F 2B F8 06          PEEK   (F8)
Mon 02/23/2015 11:48:52 AM : [iNST-SRX    ] 02 50 11.C5.51 33.5F.F6 2F 2B E2    PEEK   (E2)
Mon 02/23/2015 11:48:52 AM : [std-Direct Ack] 11.C5.51-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Mon 02/23/2015 11:48:52 AM : [iNST-TX-I1  ] 02 62 11 C5 51 0F 28 0F
Mon 02/23/2015 11:48:52 AM : [iNST-ACK    ] 02 62 11.C5.51 0F 28 0F 06          SET-MSB(0F)
Mon 02/23/2015 11:49:01 AM : [iNST-TX-I1  ] 02 62 11 C5 51 0F 28 0F
Mon 02/23/2015 11:49:01 AM : [iNST-ACK    ] 02 62 11.C5.51 0F 28 0F 06          SET-MSB(0F)
Mon 02/23/2015 11:49:10 AM : [iNST-TX-I1  ] 02 62 11 C5 51 0F 28 0F
Mon 02/23/2015 11:49:10 AM : [iNST-ACK    ] 02 62 11.C5.51 0F 28 0F 06          SET-MSB(0F)
Mon 02/23/2015 11:49:14 AM : [11 C5 51 1  ] Link    0 : 0FF8 [E201335FF6010001] *Failed Writing [E201335FF6010001]
Hey Stu
The first two commands worked (Set MSB and Peek) but the Hops Left count was not stable.  The Set MSB has a Hops Left=1 and the Peek has a Hops Left=3.  The third command, the next Set MSB, got no response after trying the command three times.  I would try a fresh set of batteries and placing the RemoteLinc near the PLM.
The Blue entries are the three repeated commands that got no response.
Been there, done that. So, I added a different RemoteLinc, fresh tested Lithium batteries, placed the RemoteLinc on top of a dual-band KPL in a Tabletop Enclosure, with the following similar result:
Mon 02/23/2015 03:43:19 PM : [14 C 6D 1   ] Link    0 : 0FF8 [E201335FF6010001] Writing [E201335FF6010001]
Mon 02/23/2015 03:43:19 PM : [iNST-TX-I1  ] 02 62 14 0C 6D 0F 28 0F
Mon 02/23/2015 03:43:19 PM : [iNST-ACK    ] 02 62 14.0C.6D 0F 28 0F 06          SET-MSB(0F)
Mon 02/23/2015 03:43:28 PM : [iNST-TX-I1  ] 02 62 14 0C 6D 0F 28 0F
Mon 02/23/2015 03:43:28 PM : [iNST-ACK    ] 02 62 14.0C.6D 0F 28 0F 06          SET-MSB(0F)
Mon 02/23/2015 03:43:31 PM : [iNST-SRX    ] 02 50 14.0C.6D 33.5F.F6 2B 28 0F    SET-MSB(0F)
Mon 02/23/2015 03:43:31 PM : [std-Direct Ack] 14.0C.6D-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Mon 02/23/2015 03:43:31 PM : [iNST-TX-I1  ] 02 62 14 0C 6D 0F 2B F8
Mon 02/23/2015 03:43:31 PM : [iNST-ACK    ] 02 62 14.0C.6D 0F 2B F8 06          PEEK   (F8)
Mon 02/23/2015 03:43:33 PM : [iNST-SRX    ] 02 50 14.0C.6D 33.5F.F6 2F 2B E2    PEEK   (E2)
Mon 02/23/2015 03:43:33 PM : [std-Direct Ack] 14.0C.6D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Mon 02/23/2015 03:43:33 PM : [iNST-TX-I1  ] 02 62 14 0C 6D 0F 28 0F
Mon 02/23/2015 03:43:33 PM : [iNST-ACK    ] 02 62 14.0C.6D 0F 28 0F 06          SET-MSB(0F)
Mon 02/23/2015 03:43:42 PM : [iNST-TX-I1  ] 02 62 14 0C 6D 0F 28 0F
Mon 02/23/2015 03:43:42 PM : [iNST-ACK    ] 02 62 14.0C.6D 0F 28 0F 06          SET-MSB(0F)
Mon 02/23/2015 03:43:51 PM : [iNST-TX-I1  ] 02 62 14 0C 6D 0F 28 0F
Mon 02/23/2015 03:43:51 PM : [iNST-ACK    ] 02 62 14.0C.6D 0F 28 0F 06          SET-MSB(0F)
Mon 02/23/2015 03:43:51 PM : [iNST-SRX    ] 02 50 14.0C.6D 33.5F.F6 2F 28 0F    SET-MSB(0F)
Mon 02/23/2015 03:43:51 PM : [std-Direct Ack] 14.0C.6D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Mon 02/23/2015 03:43:51 PM : [iNST-TX-I1  ] 02 62 14 0C 6D 0F 2B F9
Mon 02/23/2015 03:43:51 PM : [iNST-ACK    ] 02 62 14.0C.6D 0F 2B F9 06          PEEK   (F9)
Mon 02/23/2015 03:43:53 PM : [iNST-SRX    ] 02 50 14.0C.6D 33.5F.F6 2F 2B 01    PEEK   (01)
Mon 02/23/2015 03:43:53 PM : [std-Direct Ack] 14.0C.6D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Mon 02/23/2015 03:43:53 PM : [iNST-TX-I1  ] 02 62 14 0C 6D 0F 28 0F
Mon 02/23/2015 03:43:53 PM : [iNST-ACK    ] 02 62 14.0C.6D 0F 28 0F 06          SET-MSB(0F)
Mon 02/23/2015 03:44:02 PM : [iNST-TX-I1  ] 02 62 14 0C 6D 0F 28 0F
Mon 02/23/2015 03:44:02 PM : [iNST-ACK    ] 02 62 14.0C.6D 0F 28 0F 06          SET-MSB(0F)
Mon 02/23/2015 03:44:02 PM : [iNST-SRX    ] 02 50 14.0C.6D 33.5F.F6 2F 28 0F    SET-MSB(0F)
Mon 02/23/2015 03:44:02 PM : [std-Direct Ack] 14.0C.6D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Mon 02/23/2015 03:44:02 PM : [iNST-TX-I1  ] 02 62 14 0C 6D 0F 2B FA
Mon 02/23/2015 03:44:02 PM : [iNST-ACK    ] 02 62 14.0C.6D 0F 2B FA 06          PEEK   (FA)
Mon 02/23/2015 03:44:11 PM : [iNST-TX-I1  ] 02 62 14 0C 6D 0F 28 0F
Mon 02/23/2015 03:44:11 PM : [iNST-ACK    ] 02 62 14.0C.6D 0F 28 0F 06          SET-MSB(0F)
Mon 02/23/2015 03:44:15 PM : [14 C 6D 1   ] Link    0 : 0FF8 [E201335FF6010001] *Failed Writing [E201335FF6010001]
      37.7k
      376.6k
