Help with energy monitor ?
Im very new to the ISY and loving it ! My question is in regards a Aeon Labs z-wave energy monitor I picked up on discount. I had no trouble pairing and it shows current power. So my first question is there a way to update the "current power" without querying the device? And second and most importantly , is there a cheap way to collect data to as to view day, week and monthly usage, ideally broken down into times of day? I've read what i could find in the forums before bothering all of you, all i could figure out was that i would need to buy some sort of additional controller? I hope thats not the case "IM POOR" , so im reaching out to you for guidance.
Thanks bunches, Joe
Thanks bunches, Joe
I have read (not confirmed) that once the 5.XX firmware branch has been released it may offer a work around for this. Basically a state variable would be able to be included into the network resource module. This same information could then (technically) send that information to a cloud hosted data aggregator like SEG.
I am using SEG now as a back up energy resource in concert with my Dash Box (DB) and Green Eye Monitor (GEM). My goal is similar to yours but for pushing my 1 wire temperature  / humidity sensor readings to SEG.
All of this hinges on the release of firmware 5.XX and if it will allow network resources to include variables.
You should be able to do that. You need to set a device parameter to tell the device to send the value after it changes by more than a certain %. See if you can find your device here to identify the parameters to set: http://www.pepper1.net/zwavedb/
If your device is this one: http://www.pepper1.net/zwavedb/device/410
I found the following parameters to work well for me monitoring a washer and dryer:
Parameter(bytes) Value Purpose
1(1) 1 Report Multisensor as Voltage
80(1) 1 HAIL on change
90(1) 1 Enable change reports
91(2) 50 Min W change for report
92(2) 5 Min % change in wattage for report
101(4) 4 Send Watt in group 1
102(4) 8 Send kWh in group 2
103(4) 2 Send Multi for group 3
111(4) 600 Time interval group 1
112(4) 600 Time interval group 2
113(4) 600 Time interval group 3
​Check this thread for our experiences:  http://forum.universal-devices.com/topic/13055-aeon-smart-switch-dsc06106-zwus/
Michael.
Edited by MWareman
@QuietMinded, please only use those parameters if that is the correct device! There are other Aeon devices with energy monitor capabilities, and (at least he clamp meter) uses very different parameters for things. For instance, parameter 1 sets the input voltage for the wattage calculation. The Pepper1 site should detail what you need though.
Michael.
Thank you for directing me to the Pepper1 site, it took some work, but I'm up and running. Now I really want to be able to see my wattage data in days, weeks and months. Would adding the energy module have any benefit, as I have z-wave and not Zigbee? What are my options to track my wattage data?
If you can find a method to push the data to SEG or similar aggregate sites you're golden!
  • 1 month later...
Any Ideas? I have a half dozen z-wave energy modules that are working great, clearly showing current and total wattages. What I'm trying to figure out is how I can easily reset the totals without trying to fiddle with those parameters again. I don't care if it's not automated, but want to clear the totals each month when a new billing cycle starts. Is there a way to reset the devices without clearing the working parameters or something like that?
Do these devices held in the iSY not have some kind of reset button / tab to do so?? It would be a little strange to force a user to enter a device directly to reset its values.
Heh, my Aotec ZWave smart energy switches require a factory reset to reset accumulated KWH.  Firmware engineer must not have had his coffee that day...
-Xathros
-Xathros
I guess I can't throw too many stones at Smartlabs then can I? Sometimes I really wonder if some of these people step out of the bubble they surround themselves with.
Thank you both for your input, I have the Aotecs as well..... A factory reset was the only thing I could come up with, maybe someone else will be able to figure out a usable method and I'll keep on fiddling with it.
@Xathros, when you do the reset (parameter 255 I assume), does it clear the zwave network membership as well - or just reset the config parameters and metering totals?
I've only done this once so far and don't feel fully comfortable with my memory, but I believe it was a total reset and I needed to delete the unit from the ISY and re exclude/include to get it going again.  This was at a time that I was doing a fair amount of other ZWave testing so I may be mixing memories here.  If I get a chance this weekend, I will reset one of my less critical unites and confirm.
-Xathros
Edited by Xathros
Thanks @Xathros - if you do find out I'd appreciate knowing. I really don't feel like hacking thru all of my programs without being able to devote a few hours to the experiment!
  • 5 months later...
