Z-Wave Schlage Lock Setup
Yup did heal. I have a bunch of devices that say repeater when I query the device capabilities and that are close to the lock (within 6 feet of the lock)
Edited by Scyto
What's not clear to me (yet), ISY knows which devices are repeaters, but does not indicate if it knows a repeater is beaming capable. My concern is it looks like ISY calculates routes being ignorant of this, so I have some routes to my locks going thru repeaters that cannot beam. I suspect this may be something to do with unreliable lock operation in my installation. I've not been able to confirm this yet though.
Michel,
I guess the fundamental question I have is:
During route calculation does ISY consider as a route candidate for reaching a lock (or, frankly any battery powered device) repeater capable devices that ISY does not know supports beaming?
Bonus question: Is there any way beaming capability of a device can be exposed thru the API network enumeration?
The issue I seem to have is that I believe I have some repeater devices that I know don't support beaming that still list my lock as a neighbor. I would think the Sigma algorithm wouldn't allow this. Could this lead to poor or sporadic lock (and other battery device) communication?
Michael.
Hi Michael,
I am so very sorry but I really cannot answer those questions: ISY does NOT directly calculate any routes. There's a Z-Wave function we use which does that.
Worth asking though. I wonder if Sigma details how they do it though.... Must go review their document again.
Hi Scyto,
Thanks so very much for the update. What's the battery level on that door lock? Also, are there other Z-Wave devices in the same vicinity and, if so, do they work properly?
Hi Michael
I put fresh batteries in so 100%.  The repeater from Aeotec made no difference.
I believe I have multiple devices in the same area, for example the switch is within 4 feet, node 13 is within 8 feet and node 15 within 20 feet.  all my z-wave devices seem to work.
I have not tried taking the ISY from the basement to the locks location.
The lock appears to include and exclude from an aeotec stick just fine.
The lock worked on my revolv perfectly.
Fri 02/13/2015 19:36:07 : [ZW-SHOW         ] ----------------------------------------------
Fri 02/13/2015 19:36:07 : [ZW-SHOW         ] ZW003_1 uid=3 type=4.16.1 mid=99 tid=21079 pid=13619 model=0
Fri 02/13/2015 19:36:07 : [ZW-SHOW         ]    -  x25  V0  SWITCH_BINARY
Fri 02/13/2015 19:36:07 : [ZW-SHOW         ]    -  x27  V0  SWITCH_ALL
Fri 02/13/2015 19:36:07 : [ZW-SHOW         ]    -  x73  V0  POWERLEVEL
Fri 02/13/2015 19:36:07 : [ZW-SHOW         ]    -  x70  V1  CONFIGURATION
Fri 02/13/2015 19:36:07 : [ZW-SHOW         ]    -  x86  V0  VERSION
Fri 02/13/2015 19:36:07 : [ZW-SHOW         ]    -  x72  V1  MANUFACTURER_SPECIFIC
Fri 02/13/2015 19:36:07 : [ZW-SHOW         ]    -  x77  V0  NODE_NAMING
Fri 02/13/2015 19:36:07 : [ZW-SHOW         ] Node   3 - Back Porch Lanterns has the following neighbors
Fri 02/13/2015 19:36:07 : [ZW-SHOW         ]    - Repeater - Node   2 - Front Porch and Lanterns
Fri 02/13/2015 19:36:07 : [ZW-SHOW         ]    - Repeater - Node   4 - Front Balcony
Fri 02/13/2015 19:36:07 : [ZW-SHOW         ]    - Repeater - Node   5 - Xmas Lights
Fri 02/13/2015 19:36:07 : [ZW-SHOW         ]    -          - Node   9 - Front Deadbolt
Fri 02/13/2015 19:36:07 : [ZW-SHOW         ]    - Repeater - Node  11 - TV On-Off Power Switch
Fri 02/13/2015 19:36:07 : [ZW-SHOW         ]    - Repeater - Node  12 - AV On-Off Power Switch
Fri 02/13/2015 19:36:07 : [ZW-SHOW         ]    - Repeater - Node  13 - ZW 013 On-Off Power Switch
Fri 02/13/2015 19:36:07 : [ZW-SHOW         ]    -          - Node  14 - Front Lever Lock
Fri 02/13/2015 19:36:07 : [ZW-SHOW         ]    - Repeater - Node  15 - ZW 015 Repeater
Fri 02/13/2015 19:36:07 : [ZW-SHOW         ] Node   3 - Back Porch Lanterns does not support associations
Hi Michael
Yes the repeater is a neighbor of the ISY (thanks jimbo on the network routes, I had been wondering and asking how I saw info for Node 1).
Odd to me that nodes 2 and 9 don't see the ISY (these are on ground floor in same location as the front door deadbolt).  Node 4 which does see the ISY is on the first floor almost directly above 2 and 9.
Question I notice some of these report as repeaters and don't support associations (jasco switches) - does that mater?
the routes info:
Sun 02/15/2015 18:30:37 : [ZW-SHOW         ] ----------------------------------------------
Sun 02/15/2015 18:30:37 : [ZW-SHOW         ] Node   1 - [This ISY] has the following neighbors
Sun 02/15/2015 18:30:37 : [ZW-SHOW         ]    - Repeater - Node   4 - Front Balcony
Sun 02/15/2015 18:30:37 : [ZW-SHOW         ]    - Repeater - Node  11 - TV On-Off Power Switch
Sun 02/15/2015 18:30:37 : [ZW-SHOW         ]    -          - Node  14 - Front Lever Lock
Sun 02/15/2015 18:30:37 : [ZW-SHOW         ]    - Repeater - Node  15 - ZW 015 Repeater
Sun 02/15/2015 18:30:38 : [ZW-SHOW         ] Node   2 - Front Porch and Lanterns has the following neighbors
Sun 02/15/2015 18:30:38 : [ZW-SHOW         ]    - Repeater - Node   3 - Back Porch Lanterns
Sun 02/15/2015 18:30:38 : [ZW-SHOW         ]    - Repeater - Node   4 - Front Balcony
Sun 02/15/2015 18:30:38 : [ZW-SHOW         ]    - Repeater - Node   5 - Xmas Lights
Sun 02/15/2015 18:30:38 : [ZW-SHOW         ]    - Repeater - Node   6 - Ground Lights
Sun 02/15/2015 18:30:38 : [ZW-SHOW         ]    -          - Node   9 - Front Deadbolt
Sun 02/15/2015 18:30:38 : [ZW-SHOW         ]    - Repeater - Node  11 - TV On-Off Power Switch
Sun 02/15/2015 18:30:38 : [ZW-SHOW         ]    - Repeater - Node  12 - AV On-Off Power Switch
Sun 02/15/2015 18:30:38 : [ZW-SHOW         ]    - Repeater - Node  13 - ZW 013 On-Off Power Switch
Sun 02/15/2015 18:30:38 : [ZW-SHOW         ]    -          - Node  14 - Front Lever Lock
Sun 02/15/2015 18:30:38 : [ZW-SHOW         ]    - Repeater - Node  15 - ZW 015 Repeater
Sun 02/15/2015 18:30:38 : [ZW-SHOW         ] Node   3 - Back Porch Lanterns has the following neighbors
Sun 02/15/2015 18:30:38 : [ZW-SHOW         ]    - Repeater - Node   2 - Front Porch and Lanterns
Sun 02/15/2015 18:30:39 : [ZW-SHOW         ] Node   4 - Front Balcony has the following neighbors
Sun 02/15/2015 18:30:39 : [ZW-SHOW         ]    -          - Node   1 - [This ISY]
Sun 02/15/2015 18:30:39 : [ZW-SHOW         ]    - Repeater - Node   2 - Front Porch and Lanterns
Sun 02/15/2015 18:30:39 : [ZW-SHOW         ]    - Repeater - Node   3 - Back Porch Lanterns
Sun 02/15/2015 18:30:39 : [ZW-SHOW         ]    - Repeater - Node   5 - Xmas Lights
Sun 02/15/2015 18:30:39 : [ZW-SHOW         ]    - Repeater - Node   6 - Ground Lights
Sun 02/15/2015 18:30:39 : [ZW-SHOW         ]    -          - Node   9 - Front Deadbolt
Sun 02/15/2015 18:30:39 : [ZW-SHOW         ]    - Repeater - Node  11 - TV On-Off Power Switch
Sun 02/15/2015 18:30:39 : [ZW-SHOW         ]    - Repeater - Node  12 - AV On-Off Power Switch
Sun 02/15/2015 18:30:39 : [ZW-SHOW         ]    - Repeater - Node  13 - ZW 013 On-Off Power Switch
Sun 02/15/2015 18:30:39 : [ZW-SHOW         ]    -          - Node  14 - Front Lever Lock
Sun 02/15/2015 18:30:39 : [ZW-SHOW         ]    - Repeater - Node  15 - ZW 015 Repeater
Sun 02/15/2015 18:30:40 : [ZW-SHOW         ] Node   5 - Xmas Lights has the following neighbors
Sun 02/15/2015 18:30:40 : [ZW-SHOW         ]    - Repeater - Node   2 - Front Porch and Lanterns
Sun 02/15/2015 18:30:40 : [ZW-SHOW         ]    - Repeater - Node   3 - Back Porch Lanterns
Sun 02/15/2015 18:30:40 : [ZW-SHOW         ]    - Repeater - Node   4 - Front Balcony
Sun 02/15/2015 18:30:40 : [ZW-SHOW         ]    - Repeater - Node   6 - Ground Lights
Sun 02/15/2015 18:30:40 : [ZW-SHOW         ]    -          - Node   9 - Front Deadbolt
Sun 02/15/2015 18:30:40 : [ZW-SHOW         ]    - Repeater - Node  11 - TV On-Off Power Switch
Sun 02/15/2015 18:30:40 : [ZW-SHOW         ]    - Repeater - Node  13 - ZW 013 On-Off Power Switch
Sun 02/15/2015 18:30:40 : [ZW-SHOW         ]    -          - Node  14 - Front Lever Lock
Sun 02/15/2015 18:30:40 : [ZW-SHOW         ] Node   6 - Ground Lights has the following neighbors
Sun 02/15/2015 18:30:40 : [ZW-SHOW         ]    - Repeater - Node   5 - Xmas Lights
Sun 02/15/2015 18:30:40 : [ZW-SHOW         ]    - Repeater - Node  15 - ZW 015 Repeater
Sun 02/15/2015 18:30:41 : [ZW-SHOW         ] Node   9 - Front Deadbolt has the following neighbors
Sun 02/15/2015 18:30:41 : [ZW-SHOW         ]    - Repeater - Node   2 - Front Porch and Lanterns
Sun 02/15/2015 18:30:41 : [ZW-SHOW         ]    - Repeater - Node   3 - Back Porch Lanterns
Sun 02/15/2015 18:30:41 : [ZW-SHOW         ]    - Repeater - Node   4 - Front Balcony
Sun 02/15/2015 18:30:41 : [ZW-SHOW         ]    - Repeater - Node   5 - Xmas Lights
Sun 02/15/2015 18:30:41 : [ZW-SHOW         ]    - Repeater - Node   6 - Ground Lights
Sun 02/15/2015 18:30:41 : [ZW-SHOW         ]    - Repeater - Node  11 - TV On-Off Power Switch
Sun 02/15/2015 18:30:41 : [ZW-SHOW         ]    - Repeater - Node  12 - AV On-Off Power Switch
Sun 02/15/2015 18:30:41 : [ZW-SHOW         ]    - Repeater - Node  13 - ZW 013 On-Off Power Switch
Sun 02/15/2015 18:30:41 : [ZW-SHOW         ]    -          - Node  14 - Front Lever Lock
Sun 02/15/2015 18:30:41 : [ZW-SHOW         ]    - Repeater - Node  15 - ZW 015 Repeater
Sun 02/15/2015 18:30:41 : [ZW-SHOW         ] Node  11 - TV On-Off Power Switch has the following neighbors
Sun 02/15/2015 18:30:41 : [ZW-SHOW         ]    -          - Node   1 - [This ISY]
Sun 02/15/2015 18:30:41 : [ZW-SHOW         ]    -          - Node   9 - Front Deadbolt
Sun 02/15/2015 18:30:42 : [ZW-SHOW         ]
Sun 02/15/2015 18:30:42 : [ZW-SHOW         ] Node  12 - AV On-Off Power Switch has the following neighbors
Sun 02/15/2015 18:30:42 : [ZW-SHOW         ]    - Repeater - Node   2 - Front Porch and Lanterns
Sun 02/15/2015 18:30:42 : [ZW-SHOW         ]    - Repeater - Node   3 - Back Porch Lanterns
Sun 02/15/2015 18:30:42 : [ZW-SHOW         ]    - Repeater - Node   4 - Front Balcony
Sun 02/15/2015 18:30:42 : [ZW-SHOW         ]    -          - Node   9 - Front Deadbolt
Sun 02/15/2015 18:30:42 : [ZW-SHOW         ]    - Repeater - Node  11 - TV On-Off Power Switch
Sun 02/15/2015 18:30:42 : [ZW-SHOW         ]    - Repeater - Node  13 - ZW 013 On-Off Power Switch
Sun 02/15/2015 18:30:42 : [ZW-SHOW         ]    -          - Node  14 - Front Lever Lock
Sun 02/15/2015 18:30:42 : [ZW-SHOW         ]    - Repeater - Node  15 - ZW 015 Repeater
Sun 02/15/2015 18:30:43 : [ZW-SHOW         ] Node  13 - ZW 013 On-Off Power Switch has the following neighbors
Sun 02/15/2015 18:30:43 : [ZW-SHOW         ]    - Repeater - Node   2 - Front Porch and Lanterns
Sun 02/15/2015 18:30:43 : [ZW-SHOW         ]    - Repeater - Node   3 - Back Porch Lanterns
Sun 02/15/2015 18:30:43 : [ZW-SHOW         ]    - Repeater - Node   4 - Front Balcony
Sun 02/15/2015 18:30:43 : [ZW-SHOW         ]    - Repeater - Node   5 - Xmas Lights
Sun 02/15/2015 18:30:43 : [ZW-SHOW         ]    - Repeater - Node   6 - Ground Lights
Sun 02/15/2015 18:30:43 : [ZW-SHOW         ]    -          - Node   9 - Front Deadbolt
Sun 02/15/2015 18:30:43 : [ZW-SHOW         ]    - Repeater - Node  11 - TV On-Off Power Switch
Sun 02/15/2015 18:30:43 : [ZW-SHOW         ]    - Repeater - Node  12 - AV On-Off Power Switch
Sun 02/15/2015 18:30:43 : [ZW-SHOW         ]    -          - Node  14 - Front Lever Lock
Sun 02/15/2015 18:30:43 : [ZW-SHOW         ]    - Repeater - Node  15 - ZW 015 Repeater
Sun 02/15/2015 18:30:43 : [ZW-SHOW         ] Node  14 - Front Lever Lock has the following neighbors
Sun 02/15/2015 18:30:43 : [ZW-SHOW         ]    -          - Node   1 - [This ISY]
Sun 02/15/2015 18:30:43 : [ZW-SHOW         ]    - Repeater - Node  13 - ZW 013 On-Off Power Switch
Sun 02/15/2015 18:30:44 : [ZW-SHOW         ] Node  15 - ZW 015 Repeater has the following neighbors
Sun 02/15/2015 18:30:44 : [ZW-SHOW         ]    -          - Node   1 - [This ISY]
Sun 02/15/2015 18:30:44 : [ZW-SHOW         ]    - Repeater - Node   2 - Front Porch and Lanterns
Sun 02/15/2015 18:30:44 : [ZW-SHOW         ]    - Repeater - Node   3 - Back Porch Lanterns
Sun 02/15/2015 18:30:44 : [ZW-SHOW         ]    - Repeater - Node   4 - Front Balcony
Sun 02/15/2015 18:30:44 : [ZW-SHOW         ]    - Repeater - Node   6 - Ground Lights
Sun 02/15/2015 18:30:44 : [ZW-SHOW         ]    -          - Node   9 - Front Deadbolt
Sun 02/15/2015 18:30:44 : [ZW-SHOW         ]    - Repeater - Node  11 - TV On-Off Power Switch
Sun 02/15/2015 18:30:44 : [ZW-SHOW         ]    - Repeater - Node  12 - AV On-Off Power Switch
Sun 02/15/2015 18:30:44 : [ZW-SHOW         ]    - Repeater - Node  13 - ZW 013 On-Off Power Switch
Sun 02/15/2015 18:30:44 : [ZW-SHOW         ]    -          - Node  14 - Front Lever Lock
Sun 02/15/2015 18:30:44 : [ZW-SHOW         ] ----------------------------------------------
Edited by Scyto
I believe that the Jasco switches don't send status when they are changed locally - because (I think) they do not have the ability to support associations (something to do with a Lutron patent I seem to recall...)
Got it, does that matter for the z-wave lock issue I am having?
Michel Kohanim, on 16 Feb 2015 - 4:42 PM, said:Michel Kohanim, on 16 Feb 2015 - 4:42 PM, said:Michel Kohanim, on 16 Feb 2015 - 4:42 PM, said:Michel Kohanim, on 16 Feb 2015 - 4:42 PM, said:
Hi Sycto,
MWareman is correct and it should not matter.
Is the Lever Lock that's the issue?
I do see node 2 is neighbor of node 4 which is neighbor of ISY. And node 15 is the neighbor of both + the Lever Lock. So, with which one do you have communication problems?
Neither, the lock in question is a BE469 on my back door  that I am trying to include.
The ISY has not seen it on either include or exclude operations.
An aeon labs stick happily excludes / includes the lock.
The BE469 is very close to the following nodes in this order of physical proximity - 3, 12, 11, 15
The BE469 has new and fresh batteries.
The BE469 worked fine with a previous z-wave controller.
Yes I know to exclude it before doing the include.
Edited by Scyto
Try an ISY reboot then exclude/include
-Xathros
@ Michael completely deaf.
@ Xathros tried multiple reboots and exclude / include cycles
I am in middle of powering my whole house down and up to troubleshoot an insteon comms issue, I will see after that if powercyling all the z-wave devices made a difference...
Scyto,
The usual procedure is to power up the PLM first, wait a short time and then power up the PLM.
stusviews, on 16 Feb 2015 - 5:40 PM, said:
Scyto,
I am unclear what the PLM has to do with z-wave?  Also at this point of time my ISY994i is up and sending commands as usual.  It is the other circuits in the house I am powering off (not the PLM / ISY circuit)
