ability to run a program before shutdown/reboot
johnnyt
I have some things I want done before a shutdown or reboot, including sending some emails and committing some variables to NVRAM. I didn't see a way to run a program automatically whenever ISY is about to shutdown.
I normally run one manually when I know or plan a reboot but sometimes get caught in an ISY initiated reboot, e.g. I updated IP address settings recently and ISY needed to reboot but gave no warning ahead of time or chance to back out of the action.
Is there a way?
Johnny
Not for shut down, but you can mark programs to run on start up. For what I need to do, I consider that the same thing. I won't help with writing variables, but can with other things, Would that work for you?
Sent from my iPad using Tapatalk HD
Edited by paulbates
Why wait to store your critical vars. sny that I need saved, i copy to init with every change. That way I'm covered for any power fail or reboot. .
I have several variables I don't "init" each time they change but rather at strategic times during the day, or only when an else condition runs (in case of timers). This is to keep the wear on my SD drive to a dull roar. (I have over 270 variables and over 750 programs)
At start up the data is gone.
Here's my (currently manual) shutdown program:
1-1Save All Counters - for reboot
        Run Program 'Persist Counters - Daytime Use Only' (Then Path)
        Run Program 'Persist Counters in use all day' (Then Path)
        Run Program 'Persist HVAC Sensor Use Counters' (Then Path)
        Send Notification to 'jt.ha' content 'HVAC Status'
And the programs that gets called by the above or at other times.
        Time is  2:00:04AM
     Or Time is  8:00:00AM
     Or Time is  2:00:04PM
     Or Time is  8:00:00PM
     Or $sPowerFailure > 0
        $iSensorCount.Driveway Init To $iSensorCount.Driveway
        $iHVAC.FilterScore.BedroomWIC Init To $iHVAC.FilterScore.BedroomWIC
        $iHVAC.FilterScore.Furnace Init To $iHVAC.FilterScore.Furnace
        $iHVAC.FilterScore.ColdStoreDehumidifier Init To $iHVAC.FilterScore.ColdStoreDehumidifier
        $iHVAC.FilterScore.BasementDehumidifier Init To $iHVAC.FilterScore.BasementDehumidifier
        $iHVAC.Count.Dehumidify Init To $iHVAC.Count.Dehumidify
        $iCount.ColdStoreFan Init To $iCount.ColdStoreFan
        $iCount.Dehumidifier.ColdStore Init To $iCount.Dehumidifier.ColdStore
        $iHumMaxDifference.ForColdStore Init To $iHumMaxDifference.ForColdStore
        $iHumMaxDifference.ForHouse Init To $iHumMaxDifference.ForHouse
        $iCount.Dehumidifier.Bsmt Init To $iCount.Dehumidifier.Bsmt
        $iHVAC.Count.FanLow Init To $iHVAC.Count.FanLow
        $iHVAC.Count.FanHigh Init To $iHVAC.Count.FanHigh
        $iHVAC.Count.BedroomVentHigh Init To $iHVAC.Count.BedroomVentHigh
        $iHVAC.Count.BedroomVentLow Init To $iHVAC.Count.BedroomVentLow
        $iCalcOudoorTempMin Init To $iCalcOudoorTempMin
        $iCalcOutdoorTempMax Init To $iCalcOutdoorTempMax
        $iCount.SynchroLinc.SingleRun Init To $iCount.SynchroLinc.SingleRun
        $iCount.SynchroLinc.Total Init To $iCount.SynchroLinc.Total
        $sPowerFailure > 0
        $iHVAC.Count.HeatCall Init To $iHVAC.Count.HeatCall
        $iHVAC.Count.ACCall Init To $iHVAC.Count.ACCall
        $iHVAC.Count.BasementDampersClosed Init To $iHVAC.Count.BasementDampersClosed
        $iHVAC.Count.CableRoomFansOn Init To $iHVAC.Count.CableRoomFansOn
        $iHVAC.Count.HumidifierOn Init To $iHVAC.Count.HumidifierOn
        $iHVAC.Count.AC.Rate1 Init To $iHVAC.Count.AC.Rate1
        $iHVAC.Count.AC.Rate2 Init To $iHVAC.Count.AC.Rate2
        $iHVAC.Count.AC.Rate3 Init To $iHVAC.Count.AC.Rate3
        $iHVAC.Count.OfficeDamper Init To $iHVAC.Count.OfficeDamper
        $iHVAC.HeatCycle Init To $iHVAC.HeatCycle
        $iHVAC.ACCycle Init To $iHVAC.ACCycle
        $sHRV.Low.Minutes Init To $sHRV.Low.Minutes
        $sHRV.High.Minutes Init To $sHRV.High.Minutes
        Time is  1:30:00PM
     Or Time is 10:30:00PM
        $iSensorCount.LaundryRoom Init To $iSensorCount.LaundryRoom
        $iSensorCount.RecRoom Init To $iSensorCount.RecRoom
        $iSensorCount.BasementKitchen Init To $iSensorCount.BasementKitchen
        $iCount.RemoteLincWIC Init To $iCount.RemoteLincWIC
        $iSensorCount.MainBath Init To $iSensorCount.MainBath
My ISY is on a UPS and I have a mechanism to detect a power failure. I'd like to protect against ISY reboots, either because I forgot or didn't know.
Edited by johnnyt
      377k
