Can you make a dimmer, beep by a program?
Beep is available from the option box to the right of the device (along with on, off, etc.)
Are you referring to "beep duration"?
Yes.
Doesn't work for me
        Control 'Back Porch Light' is switched On
        Set 'Outside Lights' 13 (Beep Duration)
Edited by Blackbird
What is the dimmer name/number and firmware?   I have many KeypadLincs that do not have Beep feature.  Also the Beep is not very loud.
My 2477D SwitchLinc Dimmer at hardware 7.6, firmware v.44 Beeps.
Can you post the Program as well as an Event Viewer trace at LEVEL 3 showing the Beep command.
You need to add a repeat. The duration is not for how many times its supposed to beep
aaahhh, ok what is the duration for?
Duration is how long something lasts.
