Global Cache IP2SL
Can someone help me with the command structure(syntax) for issuing an RS232 command via the ISY.  I already have the ISY994i with the networking module installed and I know how to create the resource but not so sure what to use to execute the command (http, tcp, etc).  Any help would be appreciated.
The device that I am trying to control is my Key Digital Matrix Switch.  When I set up the GC IP2SL  the manufacturer suggests that the following settings be applied:
» Baud rate: 57,600
» Data Bits: 8
» Parity: None
» Stop Bits: 1
» Flow Control: None
» Carriage Return: Required
» Line Feed: Required
The command that I would like to use to create an ISY resource for will switch Output 3 to Input 1.  The command that I should use is SPO01SI03.  How do I write this command in the isy resource?
Here's an example from my setup.
sendir,1:1,1,38000,1,1,342,171,21,21,21,64,21,64,21,21,21,21,21,21,21,21,21,21,21,64,21,21,21,21,21,64,21,64,21,64,21,64,21,64,21,64,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,64,21,64,21,64,21,64,21,64,21,64,21,64,21,1518,342,86,21,3655\r\n
Heck if I can remember what this means or how I came up with this! ;) Mode is C-Escaped.
This switches an SR-22 A/B speaker switch an IP2IR.
OK, this is an IR command, which is why it is so long and painful. You've got it easy! You probably just want URL-encoded.
Edited by jtara92101
