Can't access the AJAX interface in Chrome over https
...And after several times of retrying syncing etc, the ISY has now become entirely inaccessible (even via the blue ajax interface), requiring a physical reset (aka yanking out the power cord).
Addendum: I've verified the unreliable Mobilinc behavior on two physical devices (two different iPhones). If I keep hitting "retry" repeatedly on the message mentioned above, it will eventually work (I presume this is the same as killing the app & re-launching, as sometimes it works and sometimes not).
Addendum 2: I just reverted the certificate to 512, and it's behaving the same, so it appears to be an issue created by the new firmware.
Edited by metal450
>>Did you change anything else in the security settings?
I didn't change anything after applying the update besides Network->Server Certificate->changing "key strength" to 1024->Self signed (and as mentioned, once I noticed that Mobilinc was working unreliably, I reverted back to 512 - so all settings are now the same as they were prior to the update).
>>Can you access ISY using MobiLinc on the http port?
If I change Mobilinc to use plaintext (http), the error doesn't seem to occur (I never need to click 'retry,' as I do when using https since the update).
