First program - error messages, won't save.
Hello,
Following the documentation on the wiki, I created my first program. When I tell the admin interface to save the program I get a Bad Request error followed by Discovering Nodes, Retry! error and the program doesn't save.
The program is:
 On Mon, Tue
 From Subset
 To 3:00:00AM (next day)
 Set 'Patio / Patio Light' On
 Set 'Patio / Patio Light' Off
Any thoughts as to why I am getting this error?
Thank you
Dale
btw, is there any way to copy the code from the admin interface vs. having to re-type it?
Edited by dtherio
Your program is not the reason for the error.  It is your connection to your ISY.  Try closing your connection to ISY and open a new session.
Thank you apostolakoisl,
I discovered that - eventually :)
For some reason everything else seemed to work ok. I exited the admin interface and logged back in. Then it worked.
Dale
