AT&T to end email-to-text ×
KPL odd behaviour after power failure
I would guess a magnetic contractor used to switch large motors would loose power as well and open the circuit to the motor. It may not be fast enough though...
So in the end i did click restore modem.
I remembered LeeG telling me to do it after another failure I had.
http://forum.universal-devices.com/topic/14194-programs-and-timers-not-working/
Theres the link
Thanks for everything guys.
Drew
If your PLM is dropping links, then your PLM may be dying.  The power supply capacitors on 2413s are junk and usually need to be replaced after 2 years.  Not sure if this is your issue or not.  But you might want to consider this before your plm dies completely and leaves you stranded.
I agree based on the other thread you're simply buying time and its a ticking time bomb. I am sure you don't want to be doing all of the above work 99999999 times.
