problem with programs using the the Aeron ZW089-A door sensor
Having a problem with programs using the the Aeron ZW089-A door sensor.
The If statement:
if control ‘ door sensor’ is switched on
then set ‘light’ on
doesn't work when the sensor is triggered but the statement:
if status ‘door sensor’ is on
then set ‘light’ on
does work when the sensor is triggered.
I have always been under the impression that the control statement was used as an action when the item is triggered and the status statement was used to check the condition of a device. if this is not correct could someone point me it the right direction.
Jim
