HomeKit Support via HomeBridge - Siri Voice Control
rayzor
I have just committed a change to the HomeBridge project which builds off the wonderful reverse engineer HomeKit protocol work that was done for HAPNode-JS. The HomeBridge allows you to define a platform to iterate through and automatically add devices to communicate with.
https://github.com/nfarina/homebridge
I have this working on a Raspberry Pi 2 - my basic steps were to
 1. apt-get install nodejs
 2. apt-get install build-essential
 3. apt-get install libavahi-compat-libdnssd-dev
 4. git clone homebridge (follow installation instructions on the page)
 5. modify the config-sample.json and copy to config.json
 6. run "npm run start"
I hit a couple snags along the way. For example, I hit this error and used the solution that was proposed: https://github.com/stephen/nodetunes/issues/28
Please try it out - I can say "Turn on Front Porch light" and siri will turn it on. I can say "turn on great room lights to 50" to turn it to 50% (I used % rather than ISY's concept of 0-255).
If you get stuck or have any feedback let me know. I am working on more features, trying to get status updates back, and get garage door working.
Rayzor
  • Like 4
Thanks Michel.
Would like to hear if anybody got it working, and any issues they had. I am still working on it.
I tried, but got this error. (Already posted on Git website, but still waiting for some help)
Trying to install homebridge on my Raspberry pi and got this error
npm ERR! Error: 1995645456:error:10067066:elliptic curve routines:ec_GFp_simple_oct2point:invalid encoding:../deps/openssl/openssl/crypto/ec/ecp_smpl.c:939:
npm ERR! 1995645456:error:1408D132:SSL routines:SSL3_GET_KEY_EXCHANGE:bad ecpoint:../deps/openssl/openssl/ssl/s3_clnt.c:1566:
npm ERR!
npm ERR! at CleartextStream._puller (tls.js:618:24)
npm ERR! at CleartextStream.CryptoStream._pull (tls.js:552:19)
npm ERR! at SecurePair.cycle (tls.js:842:20)
npm ERR! at EncryptedStream.CryptoStream.write (tls.js:230:13)
npm ERR! at Socket.ondata (stream.js:38:26)
npm ERR! at Socket.EventEmitter.emit (events.js:88:17)
npm ERR! at TCP.onread (net.js:395:14)
npm ERR! If you need help, you may report this log at:
npm ERR! http://github.com/isaacs/npm/issues
npm ERR! or email it to:
npm ERR! npm-@googlegroups.com
MF_Bra
Tried on my FreeBSD server, had fun fixing the dns_sd.h not being found (I had it in /usr/local/include rather than in /usr/include, could not figure out how to tell the d@mn, thing to look under /usr/local/include), now it passed the install steps, trying to run and getting
Unexpected result while probing for avahi: { [Error: dns service error: unknown error code] errorCode: -65563 }
/usr/home/andrey/src/homebridge/lib/HAP-NodeJS/node_modules/mdns/lib/avahi.js:28
  dns_sd.DNSServiceRefDeallocate(sr);
npm ERR!
MF_Bra
What command are you trying to run when you get this? This looks like an issue with node and openssl. I would make sure you update and get the latest node version.
Not sure how FreeBSD may differ. The packages may not be as up to date. Avahi is what is used for Bonjour service which apple uses, and the error code you are getting has to do with DNS. From what I have found this may mean the mdns service is not started, so I would focus around checking libavahi
avahi works fine, I can do avahi-browse -at no prob, you saying you have to have some kind of mdns process running?
Ok, thanks for the tip, I've started mdnsd (didn't know I need it) and it got me past that error.
Now - another thing - what should I have in accessories ? I mean right now I only have a platform - ISY, accessories is empty and it does not seem to like it.
[andrey@penguin ~/src/homebridge]$ npm run start
> homebridge@0.0.0 start /usr/home/andrey/src/homebridge
> node app.js
Starting HomeBridge server...
Loading 1 platforms...
[ISY] Initializing ISY platform...
[ISY] Fetching ISY Devices.
Loading 1 accessories...
module.js:338
    throw err;
Error: Cannot find module './accessories/undefined.js'
    at Function.Module._resolveFilename (module.js:336:15)
    at Function.Module._load (module.js:278:25)
    at Module.require (module.js:365:17)
    at require (module.js:384:17)
    at loadAccessories (/usr/home/andrey/src/homebridge/app.js:41:31)
    at startup (/usr/home/andrey/src/homebridge/app.js:28:29)
    at Object.<anonymous> (/usr/home/andrey/src/homebridge/app.js:188:1)
    at Module._compile (module.js:460:26)
    at Object.Module._extensions..js (module.js:478:10)
    at Module.load (module.js:355:32)
UPDATE: Never mind this, deleting accessories altogether fixed the above as well. Sorry about the extra confusion :( Server seems like it's up now, going to try to add something.
UPDATE2: It works!! Kind of :) Would not let me add the Z Wave device but added Insteon device no problem :) And Siri can turn it on/off! Unfortunately it does not work from the Watch - Siri just says something like "I can help you control your home when you using handoff on your iPhone".
But still very cool, thanks! :)
Edited by xKing
The coommand is :sudo npm install
Complete error
npm http GET https://registry.npmjs.org/request
npm http GET https://registry.npmjs.org/node-persist
npm http GET https://registry.npmjs.org/xmldoc
npm http GET https://registry.npmjs.org/node-hue-api
npm http GET https://registry.npmjs.org/xml2js
npm http GET https://registry.npmjs.org/carwingsjs
npm http GET https://registry.npmjs.org/sonos
npm http GET https://registry.npmjs.org/wemo
npm http GET https://registry.npmjs.org/wink-js/0.0.5
npm http GET https://registry.npmjs.org/elkington
npm ERR! Error: 1996251664:error:10067066:elliptic curve routines:ec_GFp_simple_oct2point:invalid encoding:../deps/openssl/openssl/crypto/ec/ecp_smpl.c:939:
npm ERR! 1996251664:error:1408D132:SSL routines:SSL3_GET_KEY_EXCHANGE:bad ecpoint:../deps/openssl/openssl/ssl/s3_clnt.c:1566:
npm ERR!
npm ERR! <http://github.com/isaacs/npm/issues>
npm ERR! <npm-@googlegroups.com>
npm ERR! System Linux 3.18.7-v7+
npm ERR! command "/usr/local/bin/node" "/usr/local/bin/npm" "install"
npm ERR! cwd /homebridge
npm ERR! node -v v0.8.8
npm ERR! npm -v 1.1.59
npm ERR!
npm ERR! Additional logging details can be found in:
npm ERR! /homebridge/npm-debug.log
npm ERR! not ok code 0
MF_Bra
Can you login to your REST API for your ISY and show me what a Z-wave device looks like? http://192.168.1.20:8200/rest/nodesfor example is my ISY URL, port, and the path and it will list out all of your devices. Paste me what a zwave one looks like. I will try a custom code fix and send it to you for testing if you are up for it.
The siri thing I do not think will work until 9.0 but I could be wrong.
BTW, it seems like it dies daily with this:
events.js:85
      throw er; // Unhandled 'error' event
Error: read ECONNRESET
    at exports._errnoException (util.js:746:11)
    at TCP.onread (net.js:559:26)
I get the following error on startup for the ISY (when i edit ISY out of the config then i have a Nest that initializes ok and will work.
[iSY] Fetching ISY Devices.
events.js:85
TypeError: Cannot read property '0' of undefined
    at /lib/homebridge/platforms/ISY.js:70:45
    at Array.forEach (native)
    at /lib/homebridge/platforms/ISY.js:57:35
    at Parser.<anonymous> (/lib/homebridge/node_modules/xml2js/lib/xml2js.js:459:18)
    at Parser.emit (events.js:107:17)
    at Object.onclosetag (/lib/homebridge/node_modules/xml2js/lib/xml2js.js:420:26)
    at emit (/lib/homebridge/node_modules/xml2js/node_modules/sax/lib/sax.js:615:33)
    at emitNode (/lib/homebridge/node_modules/xml2js/node_modules/sax/lib/sax.js:620:3)
    at closeTag (/lib/homebridge/node_modules/xml2js/node_modules/sax/lib/sax.js:861:5)
    at Object.write (/lib/homebridge/node_modules/xml2js/node_modules/sax/lib/sax.js:1294:29)
Any ideas?
Can you show the config? Edit out the password (replace with secret or 1111 or something)
    "description": "This is an example configuration file with all supported devices. You can use this as a template for creating your own configuration file containing devices you actually own.",
    "platforms": [
            "platform" : "Nest",
            "name" : "Nest",
            "username" : "me@somewhere.com",
            "password" : "11111111"
            "platform": "ISY",
            "name": "ISY",
            "host": "10.10.10.121",
            "port": "80",
            "username": "user",
            "password": "secret"
And if i delete the ISY part and leave Nest in the it will start.
Thank you
    "platforms": [
            "name" : "Nest",
            "platform": "ISY",
            "name": "ISY",
            "port": "80",
            "username": "user",
Thank you
don't you need a ", " after the ISY block of configuration ?
i don't think so because when i look at the last item in the sample then it does not have one.  But i tried it and got the following:
undefined:20
SyntaxError: Unexpected token ]
Maybe it does not like something it found in my /rest/nodes xml... They don't all have a "property" data item.
undefined:20
Sorry, with a closer review indeed all final parameters don't use the coma.
But you are far closer to play with, I'm still waiting for some help with npm install  as i get an error probably from openssl....
If the paste above was the complete file - you missing the closing }
There is mine:
    "platforms": [
            "platform": "ISY",
            "name": "ISY",
            "host": "1.1.1.1",
            "port": "80",
            "username": "user",
            "password": "top-secret"
Has anybody already managed to change the http.js from lightswitch to something else (garagedoor?). I want to open/close my maingate. It would work wt the Https.js but then I have to tell siri to switch my lights when I want to open the door.
I guess I'll be able to change that myself, but if anybody has already done that... I'll have to find out what type of device supports which methods etc. and that will take me quite some time..
Finally i could install it in my raspberry.
If I go to insteon + I can see the devices in the "add" section, and besides it doesn't  update the device status, i can control them in the software but if i ask siri to do something, "she" always respond that wasn't able to find any device.
Not sure if someone faced the same.
      37.5k
      375.5k
