Java error, cannot login
I have been having a lot of problems with my ISY26 since I made some changes to my network. I switched my internet service to FiOS and I now have an Actiontec MI424/WR. Soon after, I replaced my laptop. I should say that I usually don't have to mess with my Insteon and ISY because my system has been stable for a long time - and even with the problems I am about to describe, my programs continue to run!
My primary issue is that I cannot login to my ISY. I get to the Please Keep This Window Open screen, see the Java animation, but then Java throws an error. The error log is below.
Java Plug-in 1.6.0_10-rc
Using JRE version 1.6.0_10-rc Java HotSpot(TM) Client VM
User home directory = C:\Documents and Settings\Parents
c:   clear console window
f:   finalize objects on finalization queue
g:   garbage collect
h:   display this help message
l:   dump classloader list
m:   print memory usage
o:   trigger logging
q:   hide console
r:   reload policy configuration
s:   dump system and deployment properties
t:   dump thread list
v:   dump thread stack
x:   clear classloader cache
0-5: set trace level to
load: class com.universaldevices.client.ui.UDClientApplet.class not found.
java.lang.ClassNotFoundException: com.universaldevices.client.ui.UDClientApplet.class
at sun.plugin2.applet.Applet2ClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at sun.plugin2.applet.Plugin2ClassLoader.loadCode(Unknown Source)
at sun.plugin2.applet.Plugin2Manager.createApplet(Unknown Source)
at sun.plugin2.applet.Plugin2Manager$AppletExecutionRunnable.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: java.io.IOException: open HTTP connection failed:http://192.168.1.11/com/universaldevices/client/ui/UDClientApplet/class.class
at sun.plugin2.applet.Applet2ClassLoader.getBytes(Unknown Source)
at sun.plugin2.applet.Applet2ClassLoader.access$000(Unknown Source)
at sun.plugin2.applet.Applet2ClassLoader$1.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
... 7 more
Exception: java.lang.ClassNotFoundException: com.universaldevices.client.ui.UDClientApplet.class
I also cannot connect to the unit via telnet.
I think my firmware was at 2.6.6 the last time I upgraded.
I have tried power cycling the router, the ISY, and the PLM with no success. I have also tried connecting to the ISY through a different router with the same results.
Can anyone point me in the right direction?
Matt
Hi Matt,
I do apologize for the inconvenience.
Some questions:
1. How do you know your ISY's IP address?
2. What port do you use to telnet? Did you also try 126?
3. Have you tried http://www.universal-devices.com/99i ?
4. What firewall software do you have?
g:   garbage collect
o:   trigger logging
q:   hide console
t:   dump thread list
... 7 more
Matt
Michael,
I can see the ISY's IP address from my router.
I only tried telnet using port 126 with no success.
I had not tried /99i until your suggestion.
I use the Windows firewall.
When I went to http://www.universal-devices.com/99i I was able to login. The first thing I did was try to upgrade. I was able to successfully create a backup, but the upgrade failed saying, "Invalid length". The Admin console seems to work fine otherwise.
How should I proceed with the upgrade to 2.6.8?
Matt
Hi Matt,
If possible, please enable remote access and send us your URL and credentials to support@universal-devices.com. I really do think this is a firewall related issue since Invalid Length means:
1. The client told ISY that it was going to send a file of length x
2. ISY waited to receive the file but received a fraction (or 0) of the x
Michael,
Matt
