Memory Light Flashing
I woke up this morning to find that the memory light was flashing on my ISY. Everything else was off but the power light, which was on.
I am not able to log into or communicate with the ISY. I tried power cycling my router, the ISY and The PLM, but nothing changed.
I've confirmed that other devices in my network are working, and I can access them remotely.
Any ideas?
Hi dseigel,
Is it error light only or is it memory and error light?
I think this is networking issue: you probably have ISY configured ISY with a static IP address and another devices is using the same address (IP Conflict).
It's just the memory light.  The error light is not on.  I'll check my network settings in my router, but I can't log into the ISY to see anything.
Network lights looked normal.
I figured out the problem....I had a program that had gone rouge and was clogging up the system. I was able to log in this evening and figured it out.
