Motion Sensor
Good morning, I have a Insteon HUB, and a motion sensor, along with other RF components, and PLMs. I can get everything to work but the motion sensor. And I guess I am trying to confirm if mine is bad.
I can link it no issue, and click the setup button to run through all the states. However, once I leave it in the Off state, not motion changes it, unless I actually move the sensor and jar it a little. Any thoughts would be appreciated?
Edited by Michael
Very strange another person is having similar issues unless he physically taps the sensor. Can you try to adjust the sensitivity to its maximum and see how it reacts?
http://forum.universal-devices.com/topic/16663-motion-sensor-question/
Everything is maxed out for sensitivity but basically you have to hit it, to see any response in the events log.
Michael
Factory resetting my MS has become liturgy and is easy enough to try in this case.
Pull battery, wait a minute, press set button while connecting battery, wait 10 seconds). and then restore
(I don't delete the device from the ISY, just factory reset and restore)
Mine exhibits flaky sensing behavior when the battery is dying. It now regular practice for me to factory reset it on battery change and then use the ISY to do a restore device.
Paul
Hello Michael,
For the benefit of the forum members can you please indicate what the sticker says for the hardware production date is along with the ISY firmware version.
Interesting I have just had two batteries go dead in MS units and neither reported a lowBatt. One unit had to be factory reset and restored. The other just self-healed after battery replacement.
Some testing is coming. I need to fix my variable PS unit first.
@Michael. The MS units can take a few minutes after making adjustments to recover and act properly. The factory reset is a prerequisite for the MS units. Over half of mine (I have 9) acted really strange until factory reset.
Awesome, I will give it a try, thanks for the input. I will report back :)
Sure I am at 4.2.30 ISY, and the motion sensor is 1814 REV 2.4S, model 2842-222.
Well, I am calling this unit DOA, I am going to order a new one and see if it's me or not :) Let you know what happens.
