What is the Best way to configure IR linc and ISY-99
Can some one walk me thrught the best way to set up IR codes with IR link and ISY-99ir? I have the nec codes preloaded in my remote.Do I learn the codes into the IR linc or do I learn them into the ISY? I had this working before I migrated to the ISY-99ir
Hi Michaelv,
It's quite simple:
Go to Link Management -> Add a Button to IRLinc and follow the instructions on the screen.
It's always best if you start fresh (Remove existing links).
Having Some Troubles, For starters, I can't seem to Lean more than a couple of codes at a time. The LED on the IR Linc Keeps Blinking. Once I do learn a code to the ISY, How do I get the code to initiate a scence? I am using two differnt codes. One for on and another for Off. I Have placed the Device, an appliance linc, the learned code and the IR linc all in a scence called AMP ON. I have set the attributes to ON. Does not turn the device on when I fire the Code. What am I doing wrong?
MV
Hello Michael,
For each learned code, there should be one node on your Admin console. Once all the codes are learned, you can simply drag and drop them into scenes as controllers; just like a KeypadLinc button.
If you are not familiar with Scenes, perhaps this article will of some value:
http://www.universal-devices.com/mwiki/ ... h_tutorial
MV
