Putting multiple devices in linking mode?
I replaced a device today. I had difficulty putting both wireless devices in linking mode at the same time: Putting the second device in linking mode always knocked the first device out of linking mode.
I finally solved it buy pressing both set buttons at the same time, and probably could have done each one at a time
Is it an insteon thing that only one device can be in linking mode at 1 time?
I got everything working, just curious at this point.
Paul
I don't believe a battery operated device has the ability to multi link in the way a hardwired device can. Even though they offer a multi unlink feature in the leak, triggerlinc, MS, etc.
Is there a use case?
Paul
That would be a nice feature for scenes and other setups.
If you have everything laid out in front of you on the desk, there may be no point though. I was thinking ladder access to multiple devices.
Even if multi-lnking was available and you require climbing a ladder for each device, then the first would probably time out by the time you put the last into linking mode B)
