On Level going to 100% ??
Anyone know why the ISY insists on setting my devices to 100% after a local adustment to 66% ? i.e. if I manualy turn a switch on to less than 100%...within seconds, the ISY sends a full on?...I have flashed back to 1.0 and it still happens...
Hello PaulMVincent,
Two questions:
1. Do you have an ELK installed/integrated with ISY?
2. Are these KPLs version 1.5 or 1.6?
Hello Michel,
I do have an ELK integrated with the system. I had thought that might be causing the troubles, so I did clear the lighting information out of the ELK configuration...is there a know issue with this behavior and ELK? As for my KP versions...I will check...the problem is with all my (37) 2476D Smarthome switches...
King Regards,
Paul
Hello Paul,
If you want to integrate with ELK, please make sure:
1. you have version 5.1.4 of ELK (5.1.8 has a bug)
2. the future flag is set for all the imported devices
Hello Michel,
King Regards,
Paul
