jblackst5000 Posted September 18, 2015 Posted September 18, 2015 On Aug 24, 2015 Elk released a new firmware update to fix the problem connecting to your M1ESP with windows 10. When I updated to 2.0.34 that fixed the problem connecting to my M1EXP but now I cannot fill in data in the Elk Configuration tab in the ISY 994i admin console. When I try and enter M1ESP I.P., port and user access code I can fill it in but after I save it and go back in it is gone. It also no longer connects to Elk's M1EXP. I then launched the ISY 994i admin console using my last Windows 7 machine and everything was fine. I could fill in the data in the Elk config tap and it connected to the M1EXP. Please let me know if anyone else is having this problem and wheather a new firmware fix needs to be done for the ISY 994i. Thank You,
Michel Kohanim Posted September 18, 2015 Posted September 18, 2015 Hi jblackst5000, I think the issue may be related to an old version of Admin Console. Please: 1. Clear your Java cache: https://www.java.com/en/download/help/plugin_cache.xml 2. Go to http://isy.universal-devices.com/994i/4.3.18/admin.jnlp With kind regards, Michel
jblackst5000 Posted September 18, 2015 Author Posted September 18, 2015 Michael, Thank you very much for your help. When I cleared my java cashe and downloaded a newer version of the admin console (you attached the link to) everything works fine now. Thanks as usual for your help and great support, Sincerely,
