Network Thermostat
All,
Anyone ever heard of these or use these.  I am in search of a thermostat that is able do do everything I need (mainly have humidity control and external sensors) and be non cloud based as I cannot seem to find any insteon and or zwave options.  Oh and will this work with the network module ?
http://www.networkthermostat.com/products/wi-fi-thermostats
Take a look at the Venstar T7900. It has built in WiFi and is able to connect to their cloud service but you can disable that function and use it in a local WiFi network environment.
Perfect, so no cloud ? and controllable through the ISY via network module ?.  Now to learn how to use the network module.
Also do I need to buy the adapter or just the T7900 ?
You don't need the adapter.
Do a search in the forum for t7900, you'll find several conversations. Not sure what you can do via the ISY and Network module.
Edited by Techman
You can control via the network module.  If you want additional functionality, check out VenLink.
Techman,
I just found that, thank you
io_guy
By control can I set programs in the ISY to control the TSTAT, i assume yes.  What do you mean when you say additional functionality ?.
Getting status back and additional humidity control
I see you are in Canada, where did you get yours from ?
I emailed arrtech and they said they do not carry the t7900, off to eBay I guess
