from ISY99 to ISY994
Sorry I know this is covered somewhere but I can't find it.  Finally purchased the upgrade from the 99 to the 994.  I thought I could just back up the 99 and then when I start the 994 restore that file.  Simple right?  I am running the latest iOS (Yosemite 10.10.5). I disabled the Firewall. I don't know about the antivirus - I don't run anything special and I think the firewall takes care of that right?  The Java is up to date and I did the Xdebug thing within the Java console.
The new ISY994 is on and in Safari, I can find the ISY with the Admin Console. I log in with admin for both as instructed and the familiar blue screen shows I have no switches or programs but that is to be expected.  I then go to File - Restore ISY.  The next screens tell me to keep power on and don't mess with the wifi.  It then asks me to find the "back up"... But there is no available back up to select - in fact it doesn't show very many files to open.  I exit out and recognize the back-up from the ISY99 is a zip file so i double click it to get it out of the zip file formal and it automatically puts itself in a new named file... and guess what - it is not seen by the ISY994 either.  So what am I missing and where do I find this secret path to nirvana.
Late to the 994 dance
David
Do not unzip the backup. ISY expects a zip. Try Chrome or Firefox instead of Safari.
-Xathros
Thank you.  Half way there.  I got (and can only get) to the admin console through Firefox (the jnlp file won't see ISY yet).  Anyway, the current headache is the admin console. While it can now show me the programs Summary/Details tabs, and the Configurations tab, it will not show me the "Main" Tab.
I have cleared the Java cache and have the Xdebug thing in the Java settings.
Oh yeah - except for the "file" tab at the top the other tabs are grayed out (Link Management, Tools, and Help).  I can only 'EXIT' through the tabs on the top.  All else is grayed out.
So I can't yet use the admin console.  Anyone out there experiencing this one?
I have updated Java this week and the iOS is Yosemite 10.10.5
Thank you
Hmm,
One day later, the Admin Console populated as expected.  Maybe it took an hour, maybe more, I didn't check, but it appears to be working.  I just needed to wait.  It is working on Safari as well - now that I have restored the backup (thanks Xathros).
David
  • 1 month later...
i have both mac and pc and cannot get to ttalk to the new isy 994i
i cvannot us the console command
http://isy  (send to to another site   www.isy.com  which is a sales site)
as it required me to know the software revsion and it is not writtin on the unit and i cannot talk to it to find out.
any advice.
have done the clear cache and other things suggested , it just does not seem to want to talk to this unit, really disappjted inthe lack of doicumentation. i am moving from a 99i to 994i as vannto get units to work with 99i as all going obsolete. so have no choice. assumed this was a common update but appears not
help?
when i go through the aministrative console then it will 'seel' the 994i. and givers it a url of
http://192.168.1.10/desc
but then gives pop ups that say
"socket open failed java.net.sockettimeoutexception"
and another pop up says
"XML parse error http::192.168.1.10:80/desc"
so it can see it but something is blocking or not apper to be setup correctly in java
my jave rev is version 8 update 65  build 1.8.0+65-b17  and was updated this past couple of days sio i am sure that is good
Hi
Here are a few questions:
It sounds like you have 2 ISYs on your network, both ISYs are named http://ISYon your network. You can't find the new one by http://ISY
Here are the 99i -> 994i migration directions from the wiki,  DId you try unplugging the old unit before trying to access the new one?
Edited by paulbates
hi thanks for the input, yes i power down the old unit before powering up the new one so the old 99i should not be on the system, i will try the procedure. thanks for the help, will let you know how i get on
