Foscam Recording
zerop
Wasn't sure where to post this.
I have the "Foscam IP Camera CGI User Guide" and have been using it along with the network module to accomplish certain things on my Foscam IP camera.  I've pretty much figured out how to do it and it works.  What I don't see though is anything in the IP camera user guide on how to start and/or stop recording (manually or not via an alarm) or set schedule recording.  Am I missing something?  Does anyone have any ideas or can point me in the right direction?
My intent is to enable the schedule recording when I am away.  Therefore I'd like to be able to send a command to enable the scheduled recording when I activate my Away program on my ISY and disable the scheduled recording when I come home and turn off my Away program.
Edited by zerop
I don't have first hand info but googled "Foscam IP Camera CGI start stop recording" and that led me to the Foscam Forum.
Jon...
What model camera?
I didn't think it made much difference as I thought most of the commands were pretty universal but in case they're not I've got the following:  Foscam FI9821EP (PoE - Power Over Ethernet)
Edited by zerop
I was able to figure out how to get the Schedule Recording to work by using
/cgi-bin/CGIProxy.fcgi?cmd=setScheduleRecordConfig&isEnable=1
But now I'm trying to figure out how to turn the audio on along with the schedule recording.
I've tried, &audio=1 and &audiorecord=1 but neither of these worked.
Anyone?
Here is the full command syntax
Function: Set schedule recordconfig
Privilege: admin
Usage:  /cgi-bin/CGIProxy.fcgi?cmd=setScheduleRecordConfig
Param:  isEnable: Schedule-Record enable status, 0-disable,1-enable
        recordLevel: Level for drop frame,0-30/30,1-24/30,2-15/30,3-8/30,
                                          4-4/30,5-1/30;
        spaceFullMode: The process method when SD card is full,0-cover the
                                              oldest video and continue record,1-stop record
        isEnableAudio: Is recording include audio? 0-no,1-yes
        scheduleN: The motion alaram schedule of one week,
                                      N = 0(Monday) ~6(Sunday)
                                      For detail, see *1 bellow
/cgi-bin/CGIProxy.fcgi?cmd=setScheduleRecordConfig&isEnable=1&recordLev
el=0&spaceFullMode=0&isEnableAudio=0&schedule0=1023&schedule1=1023&
schedule2=1023&schedule3=1023&schedule4=1023&schedule5=1023&sched
ule6=1023&usr=admin&pwd=
Anyone?
If your trying to get a scheduled recording on a foscam to record with audio. . .  you can't.  At least you can't on my model and I think that this is the case across the board.  I had to use a PC and a 3rd party software to record with sound on a schedule.  It will record with audio on a motion alarm, but the longest you can set a motion alarm to record for is 5 minutes.
Edited by apostolakisl
Privilege: admin
                                          4-4/30,5-1/30;
THANK YOU!!!
This is exactly what I was looking for.  I'd scoured the internet and just couldn't find that.  Where did you get this from?  Do you have a version of the CGI manual that I don't have?  If so could you post a link to it?  I've got Ver.1.0.4 and Ver.1.0.8, neither of which shows what you gave me.
On mine you can set a schedule record with audio.
Foscam FI9821EP
System Firmware Version: 1.5.2.11
Application Firmware Version: 2.21.1.143
Plug-In Version: 3.1.0.10
Edited by zerop
  • 1 year later...
So, I have recently purchased some new Foscam PoE cameras model FI9901EP.  I have setup several network resources to control my other Foscam cameras (model FI9821EP) and everything has been working fine.  I tried using the same network resources for my new model cameras and it doesn't work.  Is there a new CGI user manual with different commands for the newer Foscam cameras?
That's one of the reasons I avoid Foscam, they have different families of software on different camera models, so features and API that works for one model do not apply to others.
One workaround is  use a NVR that does publish a featureful API, do your scheduled recording in the NVR instead of on camera.   Preferably ONVIF Profile S cameras, but anything supported by your NVR would be usable.
Even the free NVR from Milestone or ZoneMinder could suffice for a small deployment.
Edited by KeviNH
The links to both manuals are listed in camera polyglot https://github.com/jimboca/camera-polyglot/blob/master/README.md
      377k
