Scene help needed
I set up an Insteon scene via ISY containing two switches. One of the switches is connected to a load, and was added to a scene as a responder. The other switch has no load connected, and was added to the scene as a controller.
So both switches control the load - no problem there.
When I control the load using the non-load switch, everything works as expected.
However, if I control the load using the switch that's connected to the load, the other switch doesn't show the correct state of the load.  The light goes on, but the controller switch doesn't *show* that the light is on.
Is there a way to fix that?
You need to add both switches as controllers to the scene. Each controller sends a message to turn everything on, including the other switch's state.
Paul
Edited by paulbates
Paul
I should've known that.
