Thermostat 2441V Issue?
I have a Totaline 1-day thermostat and an Insteon 2441V for about a year now.  The last couple of weeks I'm seeing random heat on/off events that last only 2 minutes.  The short time is because the setpoint minus dead band hasn't been met.  So what is possibly causing this odd behavior: ISY994i, Thermostat, Insteon 2441V, PLM, RF noise?
I copied the logfile below of the last event which just happened tonight and seems to happen at least once a day.  I tried resetting the thermostat and also moved to v4.4.1 firmware but neither changed fixed anything.
ISY994i Firmware v4.4.1
Insteon: 2441V Firmware v2.5
Tue 12/15/2015 07:43:34 PM : [iNST-SRX    ] 02 50 14.F8.24 00.00.02 CB 11 00    LTONRR (00)
Tue 12/15/2015 07:43:34 PM : [std-Group   ] 14.F8.24-->Group=2, Max Hops=3, Hops Left=2
Tue 12/15/2015 07:43:34 PM : [D2D EVENT   ] Event [14 F8 24 3] [DON] [0] uom=0 prec=-1
Tue 12/15/2015 07:43:34 PM : [  14 F8 24 3]      DON   0
Tue 12/15/2015 07:43:34 PM : [D2D EVENT   ] Event [14 F8 24 3] [sT] [255] uom=0 prec=-1
Tue 12/15/2015 07:43:34 PM : [  14 F8 24 3]       ST 255
Tue 12/15/2015 07:43:34 PM : [D2D-CMP 000A] STS [14 F8 24 3] ST op=1 Event(val=255 uom=0 prec=-1) is Condition(val=255 uom=0 prec=-1) --> true
Tue 12/15/2015 07:43:34 PM : [D2D EVENT   ] Event [14 F8 24 1] [CLIHCS] [1] uom=0 prec=-1
Tue 12/15/2015 07:43:34 PM : [  14 F8 24 1]   CLIHCS   1
Tue 12/15/2015 07:43:34 PM : [iNST-SRX    ] 02 50 14.F8.24 3C.49.C7 41 11 02    LTONRR (02)
Tue 12/15/2015 07:43:34 PM : [std-Cleanup ] 14.F8.24-->ISY/PLM Group=2, Max Hops=1, Hops Left=0
Tue 12/15/2015 07:43:34 PM : [iNST-DUP    ] Previous message ignored.
Tue 12/15/2015 07:43:34 PM : [iNST-SRX    ] 02 50 14.F8.24 3C.49.C7 46 11 02    LTONRR (02)
Tue 12/15/2015 07:43:34 PM : [std-Cleanup ] 14.F8.24-->ISY/PLM Group=2, Max Hops=2, Hops Left=1
Tue 12/15/2015 07:45:38 PM : [iNST-SRX    ] 02 50 14.F8.24 00.00.02 CB 13 00    LTOFFRR(00)
Tue 12/15/2015 07:45:38 PM : [std-Group   ] 14.F8.24-->Group=2, Max Hops=3, Hops Left=2
Tue 12/15/2015 07:45:38 PM : [D2D EVENT   ] Event [14 F8 24 3] [DOF] [0] uom=0 prec=-1
Tue 12/15/2015 07:45:38 PM : [  14 F8 24 3]      DOF   0
Tue 12/15/2015 07:45:38 PM : [D2D EVENT   ] Event [14 F8 24 3] [sT] [0] uom=0 prec=-1
Tue 12/15/2015 07:45:38 PM : [  14 F8 24 3]       ST   0
Tue 12/15/2015 07:45:38 PM : [D2D-CMP 000A] STS [14 F8 24 3] ST op=1 Event(val=0 uom=0 prec=-1) is Condition(val=255 uom=0 prec=-1) --> false
Tue 12/15/2015 07:45:38 PM : [D2D EVENT   ] Event [14 F8 24 1] [CLIHCS] [0] uom=0 prec=-1
Tue 12/15/2015 07:45:38 PM : [  14 F8 24 1]   CLIHCS   0
Tue 12/15/2015 07:45:38 PM : [iNST-SRX    ] 02 50 14.F8.24 3C.49.C7 41 13 02    LTOFFRR(02)
Tue 12/15/2015 07:45:38 PM : [std-Cleanup ] 14.F8.24-->ISY/PLM Group=2, Max Hops=1, Hops Left=0
Tue 12/15/2015 07:45:38 PM : [iNST-DUP    ] Previous message ignored.
Tue 12/15/2015 07:45:38 PM : [iNST-SRX    ] 02 50 14.F8.24 3C.49.C7 46 13 02    LTOFFRR(02)
Tue 12/15/2015 07:45:38 PM : [std-Cleanup ] 14.F8.24-->ISY/PLM Group=2, Max Hops=2, Hops Left=1
Michel,
Thank you.  I will give it a try.
