Call a scene from a scene
In order to simplify things I would like to be able to call a scene from a scene.
E.g.,
Scene 1 - on/off button A + lamplink 1
Scene 2 - on/off button B + lamplink 2
Scene 3 - on/off button C + Scene 1 + Scene 2
Is this possible?
Jeff
Hi jeff
You can't call a scene from a scene.
However, you can get the same effect by creating additional scenes, and add all the necessary respondents to it
Scene 3 =  button c + button a + button B + lamplink 1 + lamplink 2
Paul
Not exactly but you can just create another scene with all of the above as responders.
-Xathros
that's how I'm doing it now.
Unfortunately it means more management (and potential for error) when you have many instead/zwave devices and scenes with devices in multiple scenes.
Thank you for your quick reply
You could also use a program. When button 3 'control' on, turn on the two scenes. When button 3 'control' off, turn off the two scenes.
There will be a small delay between them though - the two scenes will be adjusted sequentially instead of simultaneously, but it will reduce management.
It's another choice.
